Keep & Kill
V Stacks
Last Post: Blacky
10th November 2020
Posts: 64 Sportster/Buell Model: 1200C Sportster/Buell Year: 2004 Other Motorcycle Model: Triumph Bonneville Other Motorcycle Year: 1970
Loses Power
I have a 2004 1200 that starts right up and runs strong...until recently. It has 12,000 miles on it. After riding for around 20 minutes it starts to stumble with a loss of power. It doesn't die and will idle fine but try to accelerate and it acts as if it's about to run out of gas; has plenty. After sitting long enough to cool down it will start right up and run for another 20 minutes. Any ideas? I'm bringing it to the indie shop tomorrow but they are more big twin than Sporster oriented. TIA.
10th November 2020
Posts: 1,103 Sportster/Buell Model: XL883DLX Sportster/Buell Year: 1992
Start simple:
1). Check filler cap. Loosen it a bit when it starts to stumble...it could be drawing a vacuum in your tank due to clogged ventilation hole.
2). Check clogged fuel filter in petcock.
10th November 2020
Posts: 14,004 Sportster/Buell Model: 1200S Sportster/Buell Year: 2002 Sportster/Buell Model #2: XLH883 Sportster/Buell Year #2: 2003
You already have very good suggestions. I would check for fuel starvation first, either not venting or clogged fuel filter. Then check the coil and after that check the CKP.
10th November 2020
Posts: 2,833 Sportster/Buell Model: 1200C Sportster/Buell Year: 04
Could possibly be a bad carb diaphragm.
10th November 2020
No work done prior to problem.
Great info guys, a good starting point and thanks for the link!
I will report back with the result when known.
10th November 2020
Posts: 46,958 Sportster/Buell Model: XL1200CB Sportster/Buell Year: 2015 Other Motorcycle Model: CRF250L Other Motorcycle Year: 2017
Are you getting any trouble codes?
10th November 2020
My instrument cluster has been changed, po and unknown what he did so no codes show on any readout.
Neighbor mentioned a stator?
11th November 2020
Air-cooled Forever
Posts: 3,088 Sportster/Buell Model: XL 1200 C Sportster/Buell Year: 2006 Sportster/Buell Model #2: (Prev.Own)XLH Milw.Spec. Sportster/Buell Year #2: 1981
Stator would cause the battery to go dead. Fuel strainer/filter in petcock first then check the coil. Your fuel cap might not be venting.
23rd November 2020
UPDATE: We think it was a loose ground and battery terminal connection. I rode over to the shop with the gas cap loose and no issue and everything has been fine since. Only problem is it's in the upper 40's so maybe not hot enough to rule out coil or other things mentioned. I'll have to wait for Spring I guess to be sure. Thanks all you guys for the responses, much appreciated. Keep the shiny side up!
