Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Riding with disability
Riding with disability Discussions on how to ride with minor or major disabilities.
0 Picture gallery
Last Post: JonesL
0 Starter Relay Issues
Last Post: Bob F
Last Post: Tipofthelake
0 Experts Help - Factory OEM Tachometer 2001 883 Custom
Last Post: tbn
Last Post: Virto
0 Cylinder head interchangeability.. .
0 Intermittent electrical problem
Last Post: Wirelic
0 A surprising and nice experience (Peg Vibration)
Last Post: denguy
0 Smoke and top end job
0 What I learned today "Map Sensors"
0 Stalling when given throttle - video
Last Post: Boogiemanjoe
0 I'm here to introduce Gristle.
0 Touring on a Hugger
0 77 XLT smokes a lot on start up
Last Post: Larry May
0 Neat trick-- No split ends
0 Run up on the bench
0 Hammer 1250 kit with fp3
Last Post: XL Dane
10 big bore question
Last Post: dragstews
Old 5th March 2019
If a muscle is completely torn no amount of therapy will help. It has to be reattached surgically, It can not reattach itself. A muscle has to be attached at both end for it to work.
Old 5th March 2019
Akdawg Akdawg is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1969
Other Motorcycle Model: Triumph 750 tracker
Akdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud of
Had the surgery 20 years ago and the repaired side better than the non. Thing I found is make sure you work through the pain to get the range of motion back. Super important...the strength will come back with normal use but cant stress enough the ROM. Talked with a lot of others that had this and the ones that didn't pay attention to the ROM now severely limited. Did PT on the non side a few years ago when it started declining and it helped a lot, still do rubber band stretches couple times a week and that's keeping the RT strong and pain free.
Support your local ABATE
The number of kicks required to start a sporty are in direct relationship to the number of people watching.
Old 5th March 2019
Well in a get off October 2017 I received multiple tears to rotator cuff, two broken ribs, fractured clavicle and severed acromioclavicular ligament,?sp, Went a year before getting in for surgical correction. If lifting the arm it allowed the shoulder to drop down into the chest cavity and some loss of stability. I set myself up with a couple of three pound barbells and worked daily at strengthening the shoulder, (my youngest boy showed me some exercises), without stressing it. Helped a lot, but could no longer sleep on that side. Was able to do a three week, 7,177 mile run out West last August, did tire easier with some discomfort the last 1,000 miles or so. Surgery this past October and now very good motion and minimal pain. Because of my strengthening work no P.T. Has been necessary. Oh, and back to sleeping side to side. Do use the pillow between knees, many years now, with good results. Now Arthur Ritis is who I have the most problem with but I’ll take it. Learned today that my surgery was way more complicated than Inwas led to believe. Two days in hospital and discharged to home.
Old 20th April 2019
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond repute
I'm awaiting surgery referral and bought a sling with abductor cushion. It supports my arm at the correct angle from the body. I wear it at home and at night. That gave me time to practice donning and doffing it single-handed.
Since I'll be driving one-handed I installed medical grade (better construction, bearings and a stronger clamp with no protruding bolts compared to cheap spinners) steering wheel spinners on my trucks and a cheapy on my riding mower. I should have done that years ago because they are so comfortable to use. I see why truckers like them. I don't recommend waiting until after surgery since that's not a great time to learn new things or spin wrenches. I picked up two MPD spinners off Ebay for 70 bucks each. Keep an eye out for deals. They're worth having even if you don't have a medical need for one.
One chore that isn't fun one-handed is using a can opener. That's my reason/excuse for buying this
which is a great addition to my kitchen and the best can opener I've ever used.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
These work well on jar lids:
BTW so does a heat gun. I have several and tried one on a stuck jar lid. Heat guns apply more heat than the old hot water trick with no mess. If I encounter a lid I can't easily shift I'll gun it.
I've been on oxymorphone for several years, periodically suffer for a couple of days without to ensure I'm not getting attached to it, and have zero problems. I suspect the junkies are just too silly to follow instructions. Legit pain patients shouldn't have to suffer because idiot white trash can't stay away from Chinese fentanyl.
Old 22nd April 2019
Glamazon Glamazon is offline
Sportster/Buell Year: 2014
Thanks all.
Old 11th August 2019
Update, had shoulder joint replaced last Tuesday and of course won't be riding until FULLY rehabilitated. it went well and I can't stress enough how much thorough preparation makes one-armed life easier.
Prep which kicked azz:
Get Cryo cuff or similar in advance and have a convenient way to make fitted ice cubes. I use cold drink styrene cups in a plywood and metal rack I whipped up from scrap for my chest freezer. Beats chasing cups. No need to remove cups from cubes. Cold packs work too. I hang the unit from an IV stand off Amazon which will later be used for test fuel tanks in my shop.
Have spare slings including a light mesh one for showering.
Have pain meds in advance!
Make simple shirts you can don one handed.. I cut one strap on some cheap loose tank tops and used fabric adhesive to attach velcro. I can step into those like a pair of shorts without disturbing the arm.
Make various tools to function as an extra hand. I can't post pics but I tacked visegrips and channellocks upside down to eighth inch sheet and c-clamped them to my kitchen table. Channellocks are held closed by rubber bands.
Practice Tegaderm bandage/dressing swaps one handed if you live alone.
Shoes which use Salomon Quicklace system laces are outstanding.You can buy the lace kits. I will never want conventional laces again.
Old 13th August 2019
Joe_jeep's Avatar
Joe_jeep Joe_jeep is offline
Joe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond repute
i have a torn rotator cuff, a separated ac joint, and biceps and forearm tendonitis.
i chose to skip surgery for now, and did 3 months of therapy instead.
i am a a lot better! not perfect, but tolerable. i have no problem riding my bike.
you gotta work hard, and take it serious, or it wont help!
Old 14th August 2019
Medyo Bastos Medyo Bastos is online now
Sportster/Buell Year: 1966
Medyo Bastos is an unknown quantity at this point
Just don’t throw a baseball!
I just had the surgery. I was only out of work for 2 weeks. I haven’t been back on a bike yet though. P/T is making a huge difference
Old 28th October 2019
PT rocks. I do it thrice a week and at home.
Push until you get "good" pain due to fatigue, but not "sharp" pain which warns ya went too far.
Lack of pain from the joint I'd have replaced years ago had I known, priceless! I want to get all my surgeries done in my 60s before I'm too old to heal.
Due for a cortisone shot should make a big difference
