0 Run up on the bench
Last Post: 1Scooter
0 Got my Air Shocks, is something wrong?
Last Post: 92 Sporty
Last Post: FiftySixer
0 Cylinder head interchangeability.. .
0 Oem hd bobtail rear fender 2001 sportster ?
0 Smoke and top end job
0 Bobtail rear complete assembly for 2001 sportster?
0 Experts Help - Factory OEM Tachometer 2001 883 Custom
10 big bore question
0 Transmission figment
0 Stalling when given throttle - video
0 'Floppy' Forks ???
0 Carb not squirting fuel
0 I'm here to learn about my 81 ironhead
0 Bendix insulator block
0 Starter Relay Issues
Last Post: Erikdowney18
5 79 Harley 1000 Roadster Carb
Last Post: farmall
Last Post: bill smith
0 Fun or money?
0 A surprising and nice experience (Peg Vibration)
Last Post: XL Dane
0 77 XLT smokes a lot on start up
0 Picture gallery
Last Post: JonesL
muddy (68), Ohio48 (64), steelworker (60), Peg Scraper (59), txsurfer (56), eddyw (50), dejomo (42)
Old 12th August 2019
shanneba shanneba is offline
Default Friction modifiers in gasoline
I see the "New and Improved" Shell V-Power Nitro + gasoline now includes a "friction modifier". Maybe like an upper cylinder lubricant.
What will they think of next?
Marketing Alert
https://www.shell.us/motorist/shell-...-gasoline.html
NEW Shell V-Power NiTRO+ Premium Gasoline
Think all premium fuels are the same?
New Shell V-Power® NiTRO+ Premium Gasoline is engineered with four levels of defense against gunk, corrosion, wear and
friction to help keep your engine running like new. This patented formula is our best, most advanced fuel ever. Maybe it’s time to unthink what you think you think about premium fuel.
Our proprietary Shell SmoothGlide Technology™ provides our best protection against friction by filling in the rough spots in your engine,
forming a protective layer to help reduce friction and improve efficiency.
I usually run Shell in my Sportster. It is usually the same price as the other brands.
I get 5 cents a gallon (at least) with my Shell Fuel rewards card.
Join the Shell Fuel rewards program
They also run convience store promos. aka marketing
Right now you get another 5 cents for every $25 you spend inside the store (have to swipe the Fuel Rewards card)
They are also running buy 2 snickers bars and save 5 cents (my favorite candy bar )
Doesn't add up to much filling the Sportster 15-45 cents or so a fill up
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Sportster/Buell Year: 2018
Tucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura about
I live in NJ. Only Discounts on Gas is on the actual Statement itself 5 Cents on the Wawa Card.Not sure if the stations are allowed to give Promo items when they open? Haven't seen any in years. Promo items that is.
Tucsonmax1 2018 Sportster 1200 Custom, 2019 Hyundai Kona SE AWD
Old 13th August 2019
you know at one time they sold a pill that you put into the gasoline tank and it would rebuild your engine, NO FOOLING!!!!
consider from an automotive view point: cats are very sensitive to things put into the fuel. there is at present issues with oil burn and cats so the the oil is now being looked at and being modified as we speak or in this case type, lord help us!
this reminds me of AMOCO's final filter, a big HYPE!!!! amoco died and i danced on their grave, look at their history, life long legal battles with the consumer losing, of course big brother got his money from the fines but did we get a nickle back, NAW!!!!!
as an ex: look how they played the propane market.
i worked for the zero's and most of the management needed jail time!!!
Sprtstr1200s's Avatar
AVGAS 100LL. $5.69gal.
Old 25th August 2019
Mobil / Exxon now has a "friction modifier" in Supreme+ premium gasoline.
https://www.exxon.com/en/unleaded-gasoline
Friction modifier – new ingredient protects your engine by reducing wear and tear by 30%.‡‡ (Benefit available only in Synergy Supreme+ premium gasoline)
hummmm, let me see
nothing new
remember marvel inverse oilers???
people have been going non brand loyal so new gimmicks crop up.
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Gasoline sucks, can't store it anymore, attracts water and expensive...i love diesel.
how about a little cooking oil with that, smells like pop corn cooking.
even diesel is evolving. it is just about as hot as gasoline, murder on older injections.
Ireeman's Avatar
Asgardian
2 strokes yes, not so much on the 4's. Additionally the 2 strokes whilst EMP proof, shake like Lucifers Hammer.
4 stroke Yanmar is simplicity bliss...bit heavy for a bike but the range would be better than most Sportsters.
Plus as you said almost any crude or refined oil can be used.
Old 26th August 2019
I'm surprised there are no marketing claims about lubricating the fuel pump and injectors for longer life.
Red Line has said for years that SI1 fuel system cleaner included an upper cylinder lubricant.
