4 greetings from quarantine!
Last Post: sleighcrane
0 Show us the different versions of your bike!!
Last Post: lmarshall73
0 Anyone tune for and use E85?
0 Help me identify this bike
Last Post: yoshi
0 The forum got talent
0 Low Profile Scissors Lift
Last Post: ReddTigger
0 MC lift table modification
0 Who runs 70wt. oil
0 Leineweber camshaft
Last Post: mrmom9r
Last Post: Bow only
0 2006 883 pops the maxi fuse after battery change
0 2016 Oil Drain Hose Has Cracks
Last Post: joes95bobber
Last Post: jazzman
0 68 XLCH - Insight Plz
Last Post: drumbrake
0 Brad Penn, catalytic converters and EFI sportster
0 Floating front disc
0 TSM / TSSM / HFSM - How to disable alarm and/or replace unit
Last Post: 83XLX
Last Post: xraytoken
Last Post: duffy
  #101
Old 4th January 2007
Moved On Moved On is offline
Nice work UD !!
Gazza
csaintg's Avatar
csaintg csaintg is offline
Other Motorcycle Model: Softail Deluxe
csaintg will become famous soon enoughcsaintg will become famous soon enoughcsaintg will become famous soon enoughcsaintg will become famous soon enoughcsaintg will become famous soon enoughcsaintg will become famous soon enough
Looks great. I think some pinstriping would really make the paint sizzle.
05 1200 Custom, V&H Slip-on, Mustang Studded Seat w/ P-Pillion, Kuryakyn Twin Velocity Hypercharger
csaintg's Avatar
Originally Posted by Jason's Sporty View Post
They are gonna call you stripe if you ever get caught in the rain with that chopped fender. I would not wear a cape or long scarf either!!!
So if you don't have a chopped fender, do you normally wear a cape?
bshadbolt's Avatar
bshadbolt bshadbolt is offline
Other Motorcycle Model: Suzuki GSX750ESG
Other Motorcycle Year: 1989
bshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura about
I love the nice clean look around the motor with all the cables/coils/ignition switch relocated. Shows off the motor beautifully.
I want to do this as well but am not too keen on doing it myself and my indy won't do it till my bike is out of warranty (5 months to go).
Cheers,
Brett
'05 XL1200R - Pearl Yella
Motor: N4 cams, Python 2-1, Mikuni HSR42, RamFlo 400, TC88A Ignition
Handling/Comfort: Mustang Daytripper, Progressive 418HD's, Progressive fork springs, floating brake rotors, fork brace, 1200S bars
Aesthetics: chin spoiler, bikini fairing, front signal relocation
Uncledaddy's Avatar
Uncledaddy Uncledaddy is offline
Uncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud of
My wife said the same thing. I may try it.
She also commented on the stock gas cap. I've been talking about replacing it for months. She wondered how I could have finished such a big project and ended up with the same gas cap. I promised her it would be changed soon. I'm going to order the Landmark Paint Saver cap. It's clean and made in America!
Uncledaddy's Avatar
Thanks man.
What exactly did you want to do? The internal wiring or the coil relocation?
Terp84Alum's Avatar
Terp84Alum Terp84Alum is offline
Sportster/Buell Model #2: Yamaha Raider
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 2008
Terp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to behold
Man. You did a great job-that's very impressive. I give you huge props.
Ok, Uncledaddy set the bar. Who's next?
Ken from Maryland
**RIP MR. JIMI & JOHNNY G**
csaintg's Avatar
Originally Posted by Uncledaddy View Post
Thanks man.
I want to do both. I want to relocate the coil, but not sure where to put it. Also, do you have to get longer plug wires?
I plan on running my wiring internally at the same time I chop the neck. I am going to have to get it re-powdercoated, so I will drill my holes first.
I also want to add an internal throttle.
PS did you remove the forward dogbone from the motor?
Old 5th January 2007
Uncledaddy's Avatar
Here are some better pictures.
I'd like to thank everyone for their encouragement during the last couple weeks. I truly appreciated the comments and was motivated by them. I also look forward to documenting the next phase... whenever that may be.
Please feel free to contact me about any questions or suggestions. This project wouldn't have happened without the XLF and I will do my best to return the favor if possible.
Uncledaddy's Avatar
As you can see, I relocated the coil to where the cowbell was. I made a bracket which mounts to the rubber bolt and even used the wire-clamp from the horn. The stock wires will be too long. I ordered a custom pair from Magnecor. They were here in a couple days and came up to about $25.
If you can find a way to run your handlebar wires through your risers and then into your backbone, that would be killer. An internal throttle was something I looked at also but it just wasn't possible for this project. Great ideas.
Yes, I removed the upper stabilizer. The lower one is still there. It really opens up that area around the engine. I actually removed it before I started this project and rode with it for quite some time. I didn't notice any difference. The lower one needs to stay though. When I mounted the engine on the two rubber-mounts alone, it was very easy to move the engine from side to side. Two stabilizers would be better, but one works.
