0 Security system
Last Post: darwin-t
5 Other Bars instead of Buckhorns?
Last Post: KCinSB
0 Rattling noise
0 Indian FTR1200
0 A 5-gallon gas tank?
3 Wtb, Wts, Wtt, Wtg (EFIs)
0 My next trip - AMA Vintage Motorcycle Days in Lexington OH
0 Black Bike Bible
Last Post: grako122
0 Why do sportsters look small?
0 AMF Dealer Accessory Catalog
0 Mid glide
Last Post: farmerbill5
Last Post: gravydog
0 How does it feel?
0 Rubber mount questions.
Last Post: Gazotenekes
0 How many helmets?
0 Mag Wheel Valve Stem Hole
Last Post: RKN
Last Post: Moon Wolf
Last Post: kopbilly1
0 Titanium Retainers
Last Post: Cropduster
10 Greetings from upstate NY
0 carb pop on acceleration from stop
3 Possible ignition module going bad again and throwing timing off...
Last Post: groovemeisterus
0 main shaft leak
NedNimrod, jduffy01, AlanT (70), jzink0883 (69), LVBOATDOC (66), glef (61), Dogsbd (56), darkcustom (41), jon8641 (34)
  #2071
Old 18th April 2013
Geekster's Avatar
Geekster Geekster is offline
Other Motorcycle Model: Yamaha SRX-6
Other Motorcycle Year: 1986
Geekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond repute
Originally Posted by HOWNDOG View Post
When I'm using autotune it comes back and asks "scale or cap" because some values are over 127.5. It appears that when I pick "scale" it increased my displacement.
This is on a stock 883 with SE super-sucker and VnH Big Radius pipes.
HD
Had the same problem a few pages back in this thread. It was generally determined that the problem must be an exhaust leak or reversion due to very open mufflers. I did cure the problem by installing anti-reversion cones.
Old 19th April 2013
pantera's Avatar
pantera pantera is offline
Other Motorcycle Model: Kawsaki ZZR 600
Other Motorcycle Year: 2008
pantera will become famous soon enoughpantera will become famous soon enoughpantera will become famous soon enoughpantera will become famous soon enoughpantera will become famous soon enoughpantera will become famous soon enough
Just installed the Power Vision on my 2007 1200R... what a trick device.
Setup... SE ll slip-ons, & SE stage 1 breather... everything else is stock. I selected the configured corresponding tune Dynojet supplied... runs better... but seems "jumpy" mostly slowing down/idle. Does this level off once the ECM learns the new tune?
I was alarmed to see the temperature reading... averaging around 300F... is this normal? My oil is around 150F... I have no idea what the average internal temp should be (that is what the PV monitors?) What temp should I be worried at?
Lastly... the diagnostic port on the bike had three prongs... a a spot for a forth, but the wire prong was not there... is that normal? I assume if there was a problem, the power vision would not be able to read my ecm?
Old 20th April 2013
crazyeyez's Avatar
crazyeyez crazyeyez is offline
Sportster/Buell Model: 2009 XL883 Custom
crazyeyez is a jewel in the roughcrazyeyez is a jewel in the roughcrazyeyez is a jewel in the roughcrazyeyez is a jewel in the roughcrazyeyez is a jewel in the roughcrazyeyez is a jewel in the roughcrazyeyez is a jewel in the roughcrazyeyez is a jewel in the roughcrazyeyez is a jewel in the roughcrazyeyez is a jewel in the roughcrazyeyez is a jewel in the rough
my PV showed temps as high as 330 at times. not sure where it gets the reading from tho (what part of motor). but gotta remember, the oil gets its heat from the motor, and its not gonna show the same temps, unless the motor gets very hot. but you'd be in trouble by then
Nick * CrazyEyez *
2009 HD Sportster XL883Custom (XLForum.net)
2005 GMC Canyon CrewCab Z71 4x4 (355Nation.net)
1997 Pontian Grand Am SE (GAOwnersClub.com)
Old 22nd April 2013
JasonSarratt's Avatar
JasonSarratt JasonSarratt is offline
Sportster/Buell Model: Turbo XL Sidecar
JasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud of
The sensor is in the rear head on top in the chimney.... the et is measured there. Your intake temp is measured by the iat built into the tmap in the manifold behind the throttle body
Jason Sarratt
2401 SC-PBG 1350cc
www.hellcat-customs.com
Old 22nd April 2013
crazyeyez's Avatar
there ya go. lol
I re emailed DynoJet about my issue. if this don't work, gonna have to call them.
Old 22nd April 2013
KevinJ's Avatar
KevinJ KevinJ is offline
Sportster/Buell Model: White Hot Denim XR1200X
KevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud of
Don't worry about that temp.
RTM:
for sportsters, change the AT temperature range setting to:
min = 280°F
max = 410°F
Old 23rd April 2013
crazyeyez's Avatar
FINALLY got an email back from DynoJet...
seems this is more of a common issue then I thought... and he says that rerouting the interface cable away from the ignition and plug wires might help.
how y'all running the cable? ran mine up under the tank, best I could with out removing the tank.
Old 23rd April 2013
Billyj7175's Avatar
Billyj7175 Billyj7175 is offline
Sportster/Buell Model: Forty Eight
Sportster/Buell Year: 2012
Other Motorcycle Model: Street Bob
Other Motorcycle Year: 2009
Billyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant future
Should the kPa's flutter?
I was watching my kPa's while riding and noticed that they seem to flutter when there's very little load on the motor (cruise).
Is this normal?
12' Forty-Eight (SOLD), 09' Streetbob, 17' BMW R1200GSA
Old 23rd April 2013
HOWNDOG's Avatar
HOWNDOG HOWNDOG is offline
Sportster/Buell Model: iron 883
HOWNDOG is a name known to allHOWNDOG is a name known to allHOWNDOG is a name known to allHOWNDOG is a name known to allHOWNDOG is a name known to allHOWNDOG is a name known to allHOWNDOG is a name known to allHOWNDOG is a name known to allHOWNDOG is a name known to allHOWNDOG is a name known to allHOWNDOG is a name known to all
I still have my baffles in. What are anti-reversion cones?
Bottom line, you cured the "problem" but are you getting better performance, mpg, etc.?
I'm not trying to be difficult but the point of what I'm doing is to make my bike run better. I don't want to end up modding my bike to suit a possible glitch in software or electronics or maybe I'm doing something wrong.
HD
4 short lines is not enough
Old 23rd April 2013
gargoyle13 gargoyle13 is offline
gargoyle13 has disabled reputation
Hello everyone,
I have a 2012 1200 Custom Sportster completely stock. Recently my wife purchased a Power Vision PV1 for me. I have loaded DynoJets 'Improved Stock Tune' and the bike runs real well.
I have also learned that FuelMoto also has a 'Improved Stock Tune' for my bike. Not really sure if it is any different from DynoJets Tune. Since my PV was not purchased from them I do not have access to this Tune and I would like to try it.
Does anyone have a copy of FM's 'Improved Stock Tune' for my bike that I could try?
Really not sure that there is whole lot of difference if any between the two Tunes, but would still like to experiment for fun.
Thanks for any help.
jclarktnkr@verizon.net
