Last Post: SLW210
0 Rear brake caliper -- 81 XLH
Last Post: owlsplace
Last Post: doc
5 How do you Wash your Bike?
Last Post: SLW210
0 Should I buy a Sportster??
Last Post: sportyone
0 need service information for my '71 Ironheqad
0 Harley reliability .
0 72 XLH1000 Wiring Kit
0 Motoscope Mini
Last Post: deuce460
Last Post: Bow only
0 Jockey Shifter on a Right Side Shift Bike?
Last Post: dodgetrucken
0 Gave up and made a bigger fuel tank (see pic)
0 New Small Harley Model
0 Grounded
0 touchy feely sissy bar emotions poll
Last Post: xlerate
0 Wet sumping?
Last Post: Four Speed
0 2014 swingarm axle in earlier rubber mount
Last Post: jazzman
14 1974 Ironhead sportster xlch
Last Post: Ltdr13
0 Right Hand fork leg 45922-00
Phil R (76), powellsanmiguel (72), pasqualeddpas (64), maruman (62), gmhsc (61), roachhill (49), redi2ride (45), eliminator96 (39), Booncha57 (38), drewkimmel93 (26)
Nibelungen's Avatar
Master Bike Builder
Correct
speaking for myself...
on alumn i prefer to check the torque...
obviously sensitiveness and brain connected...
i think the next time for drain plug i will use again the torque wrench setted to 15 ft/lbs...
i think also 30 ft/lbs is over the strip threshold
rainbows from other worlds have colours that i don't know
Tomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant future
Working as a mechanic, for over twenty years, you get a "feel" for torque.
+1 The torque wrenches came out re-installing my rocker boxes and the cam chest cover that I understand is sensitive to pattern and torque. But my primary drain plug gets tightened "about that much" with teflon tape on the threads.
harley506d's Avatar
Sportster/Buell Model: 1200c
To be honest, i've never used the torque wrench on drain plugs etc, but i will check it tomorrow just a matter of interest.
Nibelungen's Avatar
Master Bike Builder
Yes
Interesting to know how a muscle sensitiveness... led by experience... could be positioned... in the range of stated specs...
i myself (when had the wrench setted to 22 ft lbs)... stopped far before the expected "click"... since my sensitiveness told me that was enough...
then checked the torque applied with the wrench setted starting from 10 ft/lbs... and discovered it was 15 ft lbs...
I find it amazing that we're obsessing about drain plug torque instead of important things like how many HP a fresh coat of wax on your fuel tank adds.
My excuse is that's is raining with thunder and lightning so I'm not out riding.
Nibelungen's Avatar
Master Bike Builder
Well
If you are not interested you are not forced to read by anyone...
harley506d's Avatar
I had over tightened. Clicked at 38 ft lbs. Reduced now to 26 ft lbs
Nibelungen's Avatar
Master Bike Builder
i had never thought that was possible torque at that specs on alum...
you used some sealant on the threads?
harley506d's Avatar
No sealant, just the O ring.
Nibelungen's Avatar
Master Bike Builder
Thanks for your time
