0 Pop-up gas caps
Last Post: Cablejudge
2 Missing hand control screws
Last Post: Andy56
14 A LED turn signals & load balancer how-to.
Last Post: Fifty150
0 Which Battery?
Last Post: Fifty150
0 i'm being the subject of censorship
Last Post: Fifty150
0 Happy Birthday kkbii!
0 Another oil mist problem & slobber stoppers
0 Having trouble finding bolts
Last Post: Hopper
0 Do people notice your bike?
0 How many racers are left ?
Last Post: drgonzo21
0 primary chain adjuster install 1995 1200
Last Post: Pappa G
0 Battery Fuse Stray Voltage
Last Post: SaddleBronc
0 Troubles with tach, ignition or valve float?
0 HT leads for 79 ironhead ?
Last Post: Uberstorm
0 Issues with Hammer 1275 kit
0 Front Top Motor Mount
0 Best Carb for an Ironhead?
14 Harley-Davidson Sportster S. Right For You?
5 Lefty bearing clearance?
0 Hiccup out carb , tried everything I can think of
0 Extended fork tubes and low speed handling
Last Post: jsandidge
0 Hello from Canada
Last Post: sprink
10 Hammerized 1275 and the bike rips hard!
Last Post: xena
Sourmug, UberXY (68), bsndscrn, caput001 (65), thunderrod (58), justdrew (55), wareagle0775 (46), blue (41), hellbilly713 (38), TiBaal89 (37), DWilliam (32)
engine noise, knocking, new build
Old 13th July 2013
jrwca's Avatar
jrwca jrwca is offline
Sportster/Buell Model: XL 883 Deluxe
Sportster/Buell Year: 1991
jrwca is an unknown quantity at this point
Default Noise after rebuild
Hey everyone, it's been a while. Three years to be exact. July of 2010, I snapped my pinion shaft and started rebuilding my bike. Two states, two jobs and four houses later, I finally caught a little time to put her back together. I went from bare frame to complete bike over the past couple of weeks (spare parts are normal, right?).
I just finished up getting her ready for the road and fired it up. She started right up and was sounding good. But as I listen more, I have some noise that sounds like it's coming from the right side in the cam box.
Using my trusty rubber hose, I noticed that the sound is really evident at the nose cone (with the cover off). It sounds like a high pitch metal-on-metal pinging. I don't notice it on the left side of the bike and it's definitely muted everywhere else on the cam cover.
When I rebuilt the engine, I had a reputable shop in Orange County recondition a set of used 1200 flywheels and clean up the lower end. They installed all new bushings and line reamed the cam bushings. I reamed the wrist pin bushings myself using the Jims tools.
I installed a new set of N4 cams, valves and valve seals during the install. Just prior to the breakdown, I had rebuilt the transmission and installed several new parts including an oil pump, pushrods, lifters and rocker bushings. I am using the old pistons and rings (for now).
Any ideas what it might be? I'm planning to open it back up, but I'm really not sure what would make the sound I'm hearing.
Is it possible the pistons and valves are making contact and the noise is translating down into the cam box?
I'm gonna check to see if it's only happening when the engine's hot, but would appreciate any thoughts.
Old 13th July 2013
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
please don't run it any more take the cam cover off and check to see whats wrong did you get the right side cover gaskit theres two different ones . id take a good look befor all that money you put in it get pissed away.
Old 13th July 2013
jrwca's Avatar
Ended up tearing it open this morning.
Seems the nut on the pinion shaft came loose. Not sure how that happened. I installed all that three years ago, so I don't know if I messed up torquing it or what.
Cleaned it back up and retorqued it with red Loctite. Unfortunately, it chewed up the bushing in the cam cover. Going to change the oil after replacing that bushing and try to get out any bits of the old bushing I can.
