0 2009 XB12R make over.
Last Post: salmanmr
0 Proper XLCH
Last Post: Magneto Sportster
0 Another Wrap Post
0 Top mount steering damper?
Last Post: salmanmr
0 What a birthday I've had
0 Ignition swap (compatibility?)
0 Problems relocating coil
0 Ironhead carbs
0 "03 vs 04+ Cylinders & Heads: Different Carb Bracket?
Last Post: screndname
0 Gearing Help
Last Post: BigMek
0 baker 6 in 2000 883 conversion primary vent drips
Last Post: Randy_rots
0 Fixing Digital Gear Indicator
0 Top end failure
Last Post: Mission1
0 Info needed on mini sumps.
0 Graduated to Ironhead
0 Inherited Ironhead
0 yost power tube guy
0 FDR Drive pothole did this...if u can believe it
0 Looking for an xlch engine
Last Post: Medyo Bastos
0 Chinese S&S carbs
0 dieseling ? solenoid ? help
Last Post: keithnh
edelbrock, machining, sportster 1200 project
Old 29th January 2019
twistediron twistediron is offline
Sportster/Buell Model: 883 hugger
twistediron is an unknown quantity at this point
not milling because i own a lathe not a mill and the cams are stock 883 cams
Hippysmack's Avatar
Cool,
I'd definitely like to see the jig and setup.
I haven't found jack on Edelbrock pistons.
was thinking i would just use a four jaw chuck but havent tried it yet ... ya they say edelbrockbut i think they are made by je becuase they also say srp on them think they are suppose to be 10.3-1
Hippysmack's Avatar
Woops,
My head was on a 3 jaw chuck.
Still want to see it though.
Pics or it didn't happen.
Toejam503's Avatar
Sportster/Buell Year #2: 1981
Originally Posted by twistediron View Post
hey im new to the site and am building a 97 883 i recently bought a top end off of a guy off here (t120r) and want to do some changes to the setup the main thing i want different is he was running 11.29-1 compression ratio on pump gas which is to high for me i want 10-1 maybe up to 10.5-1 at the most the setup is 1200 cyls with edelbrock domed pistons and edelbrock heads he shaved . my thought was instead of buying new pistons id like to do the calculations and lathe off the domed pistons. my worry is that i know some pistons have a different material or coating that if removed will cause the pistons to melt down
any advice would be great .
As long as these pistons are forged and not cast, you should be able to customize them. How much? measure twice and cut once.
rocketmangb's Avatar
1200 pistons under 883 heads ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
no edelbrock perfomer 1200 heads shaved 0.030''
measure the skirts, pistons are not always round which could be an issue chucking it up.
Pistons are rarely round !
very true for what most will encounter. but there are round pistons like the old trunk pistons with upper and lower rings. there are even cameo cooky shaped pistons.
https://i.redd.it/91fcxazg3npz.jpg
