0 fuse block
Last Post: xElvis
0 fork oil
0 Emission hose loose
0 Reflectors...Yeah, or Neh
0 73 XL 1000 Sportster - SOLENOID BYPASS
Last Post: thefrenchowl
0 Can’t go over 70mph
0 Wet Sumping (No oil returning)
Last Post: FalcoFlash
0 Resto-Repair 84 ironhead
0 Air filter Q
Last Post: Billy1200
Last Post: maltesefalcon
Last Post: Akdawg
0 ultima install without VOES
Last Post: supermotolew
0 TC88A Maps for 883 to 1275 Basic Converstion
0 Chinese S&S carbs
Last Post: T. Clark
0 Recent 1275 Dyno Tune
0 Hammer 560 VS 570 Felt differences?
0 2006 XL1200 OEM Battery Dimensions
merc, schvamf (48), MikeLightnin, o2man98 (40), Toadz (32), WingNut15B (32)
drag pipes, fouling, ironhead 1972, super b
Old 29th May 2019
You need to learn to properly set a carb. If you set the idle mix cold it will blacken the plugs.
The idle mix screw does not get set to a number, that is just to get it running.
You have to fully warm the motor, that means a hot oil tank, usually a 30 min ride, not around the block.
After you get it fully warmed up you turn the idle mix screw in until the bike misfires then back it out till it just smoothes out. Then set idle speed to no less than 900 and repeat tweaking the idle mix.
I usually set my hot idle higher so it will idle better cold.
NOTE: Prolonged idling at low speeds will ruin your pistons from lack of oil, the pistons are splash lubed and need 900 rpm MINIMUM.
NOTE: Do not tune for best response free reving. You will wind up too rich and blacken plugs.
TIP: a propane torch can be used to burn off the carbon deposits and restore a fouled plug.
RE: plug gap, you will not be able to run a large plug gap unless you have a 3 ohm coil and an ignition module capable of driving it. (points coil is 5 ohms)
TIP: S&S idle mix screw is very sensitive, 1/8 turn is a big adjustment
TIP: Set idle correctly and low speed jet first before going after main jet. A very high percentage of fuel is supplied by the idle/low speed circuit, changes there affect all modes of operation.
Old 29th May 2019
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Well S&S recommends the main jet to be between .062 and .070 for the Super B.
So you are at the rich end of the range. Drop it down some.
Now the Super B does not have an accelerator pump so many jet rich to lessen the low speed stumble.
Here is the link for the tuning info
https://www.sscycle.com/docs/default...4.pdf?sfvrsn=4
Old 29th May 2019
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant future
I think if it was a fuel problem both plugs would be fouling.
Murphy's Law :vvet:
