0 Tire pressure
Last Post: mvent
Last Post: fafcpa
0 Chinese S&S carbs
0 Adjustable main with mag
Last Post: davixlrtt
Last Post: mac93
0 Mounting seat with out frame tabs?
0 Cleaning carbon build-up
0 Changing Battery(with factory Alarm)
0 Gasket placement
Last Post: Billy1200
0 Top end failure
Last Post: Mission1
0 What a birthday I've had
0 Mystery transmission piece??
0 Keihin Butterfly crack
Last Post: Tipofthelake
0 XR mutt race bike progress
Last Post: supermotolew
0 Info needed on mini sumps.
Last Post: mrmom9r
0 Don't Think I Ever Did This
Last Post: Veeflys
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sticky Ironhead trans
0 Inherited Ironhead
0 HF bike lift
Last Post: BigLerowski
0 Graduated to Ironhead
Old 3rd June 2019
Toejam503's Avatar
Sportster/Buell Year #2: 1981
Maybe this simplified wiring diagram would help. It's from Sportsterpedia.com
http://xlforum.net/forums/showthread...=426562&page=4
Old 3rd June 2019
Lone Rider's Avatar
Sportster/Buell Model: 1200
I would think if you are doing away with the start switch you could just cap them off, separately not together as that would send power to the starter, since you are doing away with the switch I imagine you are going with some kind of manual switch?
Old 3rd June 2019
matt_m_72 matt_m_72 is offline
Sportster/Buell Model: xl1200
Other Motorcycle Model: 02 Electra Glide Classic
matt_m_72 is an unknown quantity at this point
it will have a old school start button
Old 3rd June 2019
like this https://www.ebay.com/itm/Push-Button...IAAOSwH1Vc2z8e
Old 4th June 2019
Lone Rider's Avatar
let me back track for a moment, how many wires do you have currently going to your factory start switch? My thinking is you should have three, obviously you have a grey and white, there should be another, one should be the "hot" (+) wire, one should be the "run" wire, and one should be the "start" wire, being that you are doing away with your "kill/run/start" switch, the hot wire should tie directly to the "run" wire, and then the hot wire should branch off to one side of the start button, and the "start" wire to the other side of the start button.
Old 4th June 2019
the white wire goes to the start button and to the kill switch.
Old 4th June 2019
Toejam503's Avatar
You ever thought about using a starter with the start button built in?
Old 4th June 2019
Lone Rider's Avatar
Still should be three wires going to it, from what I have been reading the 03 has the same wiring schematic, I will check it in the AM.
Old 6th June 2019
Lone Rider's Avatar
My apologies it's been a long time since I've seen the stock controls, I forgot the "kill/run" switch was separate from the "start" switch, so looking at my schematic, the grey and white should go together.
Old 6th June 2019
that is what I was thinking, ty for the start Lone rider!
