0 What a birthday I've had
Last Post: jharback
0 Chinese S&S carbs
Last Post: bill smith
0 Keihin Butterfly crack
0 Belt Guards/Lowering Brackets
0 Another Wrap Post
0 2009 XB12R make over.
Last Post: salmanmr
0 Proper XLCH
Last Post: Magneto Sportster
0 Top mount steering damper?
Last Post: salmanmr
0 Ignition swap (compatibility?)
0 Problems relocating coil
0 Ironhead carbs
0 "03 vs 04+ Cylinders & Heads: Different Carb Bracket?
Last Post: screndname
0 Gearing Help
Last Post: BigMek
0 baker 6 in 2000 883 conversion primary vent drips
Last Post: Randy_rots
0 Fixing Digital Gear Indicator
0 Top end failure
Last Post: Mission1
0 Info needed on mini sumps.
0 Graduated to Ironhead
0 Inherited Ironhead
0 yost power tube guy
0 FDR Drive pothole did this...if u can believe it
1972, ironhead, sportster
Old 21st June 2019
xlhshawn xlhshawn is offline
Sportster/Buell Year: 1972
xlhshawn is an unknown quantity at this point
thanks, will try that, no to the paint or powder, looking for stock look...thanks all
Old 21st June 2019
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
FYI for price comparison,there is a guy on Phx local c/l that charges $50/hr. I would think he could do a case in an hr minimal charge. Not sure where you are, but there is probably someone comparable. $50 no muss I would think would be cheap, not sure what you value your time in a passion project. No post cleanup. The soda is minimal clean up if you go the home route.
Old 21st June 2019
Opinions on blasting.
http://xlforum.net/forums/search.php?searchid=9775931
Hazmat Life
Old 21st June 2019
Stock look = blasting with walnut shells?
Old 21st June 2019
someone painted my cases black in the '70's.i wanted to remove it cases together in the frame.i scraped most of it off then used aluminum wheel cleaner for the rest.it has a mild acid in it.be careful though acid means acid.
Old 22nd June 2019
frogg_nutts frogg_nutts is offline
Sportster/Buell Year: 72
Other Motorcycle Model: XLH
Other Motorcycle Year: 80
frogg_nutts has much to be proud offrogg_nutts has much to be proud offrogg_nutts has much to be proud offrogg_nutts has much to be proud offrogg_nutts has much to be proud offrogg_nutts has much to be proud offrogg_nutts has much to be proud offrogg_nutts has much to be proud offrogg_nutts has much to be proud offrogg_nutts has much to be proud offrogg_nutts has much to be proud of
If You can get away with it, run them thru the dishwasher.
Old 23rd June 2019
Campsurf's Avatar
Campsurf Campsurf is offline
Sportster/Buell Year: 1970
Other Motorcycle Model: Triumphs
Other Motorcycle Year: 1964
Campsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really nice
Vapor Hone... this a slurry of glass beads with water ... not a cheap set up but some people offer their services ...
https://www.youtube.com/watch?v=700Qwy9mFFs
Old 23rd June 2019
jcn59 jcn59 is offline
Sportster/Buell Model: 1200
Sportster/Buell Model #2: 1200
Sportster/Buell Year #2: 1994
Other Motorcycle Model: Aspencade
Other Motorcycle Year: 1986
jcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond repute
Brownell's, the gun parts supplier in Iowa(?) offers a DIY product called "Cerakote" and a different product (Lauer?) that is a 2 part epoxy finish in a single (trick) spray can that is near indestructible. Both available in a variety of colors. Both probably more wear resistant than powder coat. I've used both on firearms but I like the epoxy better. These products might offer alternatives to the "ship it elsewhere" procedure for parts finishing.
Gone but not forgotten: RD 350 Yam, Kaw 3 cyl. 500, Kaw 900 Z1, 750 Honda SS, etc.
