0 Transmission issues
Last Post: Tipofthelake
0 Info needed on mini sumps.
Last Post: thefrenchowl
0 XR mutt race bike progress
Last Post: Scott
0 Looking for an xlch engine
Last Post: Medyo Bastos
0 WTB: 1996 Sportster stock-ish exhaust and mid controls
Last Post: PRICHMON
0 Keihin Butterfly crack
Last Post: jasnoc
0 Cut Wiring, no spark.
0 Chinese S&S carbs
Last Post: 11B40
0 Top end failure
Last Post: Mission1
0 Ironhead high speed cruise prob
Last Post: Oldmxdog61u
0 First Harley - 1975 XL1000 Café Project
0 Belt Guards/Lowering Brackets
Last Post: Jcolleyoh
Last Post: SprtyXL
0 Rear Exhaust Tappet Mount Block
Last Post: knocknakilla
Last Post: james beam
Last Post: keithnh
FORCE50 (68), marcus (55), gardkarlsen (50), dhoppe1 (42), Hagen (42), tdyer55 (38)
Old 6th July 2019
dieselvette's Avatar
Default Oil cap problems - Bikers Choice 02-073
Wondering if I should dig deeper, or if this oil cap is just a pos.
https://www.ebay.com/itm/311385473079
Bike has lots of miles and wet-sumping problems "sometimes" which I haven't fully diagnosed. Read all the gobs of info on sportsterpedia (Thanks to the contributors that's an awesome resource!) and I know how to diagnose it, just confused by this little anomaly that's come up.
I got the oil cap because I wanted knurly grips on it because lately my oil cap is practically impossible to unscrew. Added bonus is the temp gauge.
Problem is the end of the stick on this cap isn't sealed - it is like a straw. Inside is a shaft attached to the temp gauge with just an oring around it under the spring. So apparently pressure will push the oring up and oil come out around it through the "straw" which then ends up all over the side of the bike. I drained some oil and ran the level as low as I dared, same problem.
So I ordered new umbrella valves, and tomorrow will check the vent-to-cam-chest line for obstruction.
Question is has anyone tried this oil cap? Any better suggestions? The stock one was OK and looks fine except I can't turn it. The new one is only slightly easier and I'm wondering if I need a new oil tank that maybe mine is warped?
____________________________________________
FIND HELP WITH YOUR SPORTSTER HERE: http://sportsterpedia.com/doku.php
If men can build it, men can fix it. - Tim Allen
2004 1200 Roadster Custom-Electra-Glide-Sport-Touring-Edition
SE air cleaner w/venting routed outside a/c
Supertrapp 2:1 pipe - usually 20 discs w/closed endcap
Stock CV carb w/ Yost tube + DS idle mixture screw
Cycle Electric 38A charging system
TC88A ignition
0.030 head gasket, zero deck-height
Hammer 570 cams
Bronze oil pump gear, updated oil pump
30-tooth HDI belt sprocket (137-tooth belt)
Old 6th July 2019
Hippysmack's Avatar
Hippysmack Hippysmack is online now
XLF member JohnK found that the internal sleeve in the OEM caps are weak and apparently easy to break.
That ended with the cap popping up out of the blue though.
That article is here:
http://sportsterpedia.com/doku.php/techtalk:evoil04b
And there is a certain way it has to be installed:
http://sportsterpedia.com/doku.php/t...oil04#oil_cap1
But the cap is apparently difficult to turn.
Maybe the plastic threads warping?
Would love to add some pics of your new cap to the pedia if you get a chance to snap a few.
Old 6th July 2019
Bored now Bored now is offline
Sportster/Buell Model: 883
Bored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond repute
Three of the four reviews on that Ebay page say the cap leaks.
Old 6th July 2019
I know, didn't see that until later On the other hand, people are idiots and it's plausible their bikes have a venting problem too.
I'm going to hang onto it until I've solved my venting/tank spout problem and see if it still leaks. Then even if it works good I'm still not going to run it because it's a liability.
Old 6th July 2019
Hippysmack's Avatar
I would like to see how you address the wetsumping issue.
When you pull the breathers, if you could pull out the mesh and expose the inside, I need see a pic of surface behind the mesh.
Old 6th July 2019
if i am reading this right, oil is pushed up through the center of the dip stick and not the threaded cap portion??
a pic of the cap and drawn in leak path would help
perhaps the original cap can have a rubber ring installed for better grip, sorta like a garden hose nozzle.
as a side note, make sure the equalizing line between tank and cam chest is not restricted or the tank can build pressure.
did not hd get rid of the mesh.
Old 6th July 2019
After draining the oil and further inspection, there will be a lot more to this story than I thought. But first I'll stick with the oil cap issue. Hippy is looking for detailed info about the aftermarket BC cap, so here ya go. You can see the temp probe sticks out, and goes through the hole down the middle:
The hole is open through to the bottom, like a straw. The o-ring has a landing inside the straw, it fits OK but I can see how it wouldn't hold much pressure. The pop-up design and all is basically the same as OEM, except the coil spring is a little heavier.
Old 6th July 2019
Here is my theory about the original cap
I think it's binding because it's a tight fit inside the oil tank, and the spout is not aligned well with the chrome bezel in the side cover. After removing the side cover the oil cap works a lot better, although still not as easy as it should be. (It also helps that you can get a hand around it without the side cover in the way.)
If you look closely at the pic, you can see scratch marks that follow the angle of the slot of the cap
Inside the spout, if there's anything to see here?
Normally this is all squeaky clean, and I'm anal about the oil cap being clean when re-installing. But the scratches could be from foreign material in the oil? Could be over-thinking it. More on that later.
Not really interested in spending $200 on a new oil tank if I don't have to. Maybe the side cover will get "modified" instead.
Hippy - I won't have parts for the top end until next week, so I'll post pics of that later. For now it looks like I'll be cleaning out the vent hose tonight, and pulling the oil pump to get a close look at that.
Old 6th July 2019
on the aftermarket stick, the white piece stays in the tank and the probe and black piece comes out. if so the oring and backup washer is not expanding enough to seal.
now for the original cap, i have run across sticky oil caps on autos and the #1 issue is the oring itself. after awhile, they are not as pliable and have a tendency to grip. what you can try is a silicon oring or even teflon. another thing to try is a quad-ring.
Old 7th July 2019
That's a great point. Will put a new oring on the original cap.
The aftermarket one, if I was going to keep it i'd try a different oring or something on the shaft. But I may be content just getting my $50 back.
