0 Chinese S&S carbs
0 "S" model specific Q&A
Last Post: Paul.W
0 Learning Wrenching Resources?
Last Post: Paul.W
0 Ground Up Beginner Build
Last Post: Paul.W
0 Tappet blocks and tappets
0 XR mutt race bike progress
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 WANTED, Mid Controls for 2002, 883 Sportster
Last Post: tylermiller
0 Why No Tachometer?
Last Post: Oldmxdog61u
0 Brotherhood of the traveling lid
Last Post: BigLerowski
Last Post: Edster
0 Coil readings
0 New guy from IL
Last Post: Bow only
0 Top end failure
Last Post: Tipofthelake
0 Valve Lengths?
0 3/4” Axle Drum Brake ??
0 primary cover
0 Why such heavy oil in Sportster?
0 Andrews 5th Gear Mainshaft Swap
Last Post: Diemos
0 Key
daggar rider, The Brit (67), MGN54 (66), beau-kat, bkmthdff (55), af_sting (51), ofo (49), LOSTHIGHWAY420 (46), coxja (40), rickeybyrd (35)
push button, solenoid, starter, sticking, sticks
Old 27th October 2016
Kidcoocoo Kidcoocoo is offline
Kidcoocoo is an unknown quantity at this point
Since you are manually activating the solenoid is the power to the relay still required or can it be detached?
Old 28th October 2016
Originally Posted by DogBunny View Post
Glad to see that this old thread is still helping people. I finally fixed the pictures, they now all show up correctly in the very first post of the thread. It only took me 4 years to fix those pictures...
Thanks for posting the thread & fixing the pictures...
I added a link to this thread in the Starter Section of the Sportsterpedia:
http://sportsterpedia.com/doku.php/h...enoid_assembly
__o~~o__
IXL2Relax
Reference the XLForum Sportsterpedia
Old 14th May 2017
beanhead78 beanhead78 is offline
beanhead78 will become famous soon enoughbeanhead78 will become famous soon enoughbeanhead78 will become famous soon enoughbeanhead78 will become famous soon enoughbeanhead78 will become famous soon enoughbeanhead78 will become famous soon enough
sweet!!!!! i already have the aftermarket push button, but mine stuck on me yesterday about 45 miles away from home. going to try clean everything up see if it works. after i put my primary side back together and throw some cat litter down where i spilled gear oil everywhere....haha
Old 11th November 2018
Dusz Dusz is offline
Sportster/Buell Model: XL883L
Dusz has much to be proud ofDusz has much to be proud ofDusz has much to be proud ofDusz has much to be proud ofDusz has much to be proud ofDusz has much to be proud ofDusz has much to be proud ofDusz has much to be proud ofDusz has much to be proud ofDusz has much to be proud ofDusz has much to be proud of
Just came across this as the solenoid on my 2013 883 is clicking. It is less than 6 weeks since the bike was serviced and MoT'd and has only covered just over 5000 miles. Bit disappointed in the no start problem since my '81 CX500 Custom still starts fine.
The question I have regarding the mod is how far is the travel of the manual actuator as I wondered if it could be made shorter?
Old 18th November 2018
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond repute
The travel distance is necessary for full pinion/ring gear engagement.
BTW your CX500 is much easier to crank than a Sportster engine due to smaller displacement. Your Sportster starter is an excellent unit and easy to work on. The little Bosch style starter relays don't last forever but they are inexpensive and common at auto parts stores. Bring old relay as a sample. Some owners parallel two relays for more current to the solenoid.
When you install a pushbutton take the opportunity to replace the starter contacts if they aren't in very good condition. They are the usual cause of sticking. Kits are cheap as these Denso OSGR Light Duty starters are on tens of millions of cars and trucks.
This example kit has all the parts you'll need to swap contacts. There are no special snowflake kits so don't pay a premium. You'll also need a primary gasket/seal kit and a starter motor gasket unless you can fiddle the lowest nut off the stud with the starter in place. I'm not that patient and my nuts are usually corroded.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
In an emergency you can pull the stock solenoid cover (ensure trans is in neutral!) and operate the solenoid by pushing with a screwdriver. If you have a drill you can drill the cover, reinstall, then actuate the solenoid with a round screwdriver. The screw and spring trick is old and excellent.
Old 26th November 2019
DoItMyself DoItMyself is offline
Sportster/Buell Model: 1979 Sportster Ironhead
Sportster/Buell Year: 1979
DoItMyself is an unknown quantity at this point
DogBunny-could you please send to me or re-post the pics? I'm rebuilding/repairing the solenoid to my 1979 Sporster Ironhead XLH
Thank you!
DogBunny's Avatar
DogBunny DogBunny is offline
Sportster/Buell Model: XLH883-1200 Ol Black Mare
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Yam. XS650 "Angry Hornet"
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Yam. XS650 "Bug Killer"
Other Motorcycle Year: 1976
DogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to behold
Sorry, I wish I could help you, but those pictures are lost...
