0 FDR Drive pothole did this...if u can believe it
0 Don't Think I Ever Did This
0 Hammer 1250
Last Post: davesz1r
0 04 brake upgrade question
Last Post: Calcustom
0 Primary Dip Stick?
0 Noise and rod play
0 1966 XLH...sort of
Last Post: Captain Johnny
0 Bikers choice main jet threads
0 Sportster 883 mini electronic speedo
Last Post: Doc308
Last Post: farmall
0 Spark Plug Indexing
0 1992 XL ignition explained
0 Counterfeit Mikuni Carbs
Last Post: davesz1r
0 front exhaust pipe keeps slipping off, help
Last Post: 67170
0 Stairman question
0 New Guy Here - Handlebar Question
Last Post: LLOYD883
0 yost power tube guy
5 Is my timing correct?
Last Post: rerb
Last Post: Bone
debster, brknwng (72), TerryW (67), doc_davo (65), clh, Hanoverfiste (48), XL-DecentGlide (45), nobleff517 (45), joekangiser (42), scroggy (36), sgvrider (33)
1972, electronic ignition, twin plug
Old 6th August 2009
Charley Snow's Avatar
Charley Snow Charley Snow is offline
Sportster/Buell Year: 1972
Other Motorcycle Model: BSA,Triumph,Enfield,BMW
Other Motorcycle Year: OLD
Charley Snow is an unknown quantity at this point
Default Electronic Ignition
Hi Folks,
I am looking to fit electronic ignition to my 1972 XLH 1000. As I only have experience with European motorcycles and ignition systems before this Sportster, I am looking for some assistance as to which system to buy.
The bike is as near stock as I can get it. (I live in Spain and we pay 30% tax on all imports from the US of A so I would like to get it right.) I have the idea to go twin plug head in the future, so if there is a system that can deal with one plug per cylinder now and twin plug per cylinder in the future, I would like to know about it. Or a place where I can find out about it.
Thanks for any in put.
Old 6th August 2009
The Crane Hi-4 http://69.20.53.62/ and the Ultima http://www.ultimaproducts.com/ignite.htm are popular choices.
Old 6th August 2009
johnnyjellybean's Avatar
johnnyjellybean johnnyjellybean is offline
johnnyjellybean is on a distinguished roadjohnnyjellybean is on a distinguished roadjohnnyjellybean is on a distinguished roadjohnnyjellybean is on a distinguished road
I have the Crane Hi-4 and love it. Easy starting and you can adjust the timing curve to the type of riding you do. Also has the adjustable rev limiter.
2007 96" Twin Cam FXDB 87HP 96TQ
Old 6th August 2009
Have had the Crane for years and am highly satisfied with it. Pretty sure you either get a single plug or dual plug version. Don't think one swaps back and forth between the 2 modes. I run a single plug singlefire version. With the adjustability built in I have no pinging problems with 93 octane pump gas and 9:1 compession.
Old 6th August 2009
fdny37's Avatar
fdny37 fdny37 is offline
Senior Master Bike Builder
Sportster/Buell Year #2: 1968
Other Motorcycle Year: 2014
Sorry Buck but you are mistaken, the Hi-4 can go from single plug to dual plug by just adding a coil and a jumper wire. So Charley you can switch the Hi-4 to run dual plugs in the future anytime you want.
Old 6th August 2009
Thanks for the calibration FDNY (BTW born and raised in Queens), I was going from memory, so much for that idea, shoulda checked the specs.
Old 6th August 2009
No switch on the Hi-4 for dual plugs, and none needed. No switch for dual/single fire either - for this you have to get a different model. The Ultima is more flexible, has more options and settings, costs less.
