0 "S" model specific Q&A
0 Highway cruise speed
Last Post: lespaul6
0 N65C or N65A
Last Post: lespaul6
0 Tappet blocks and tappets
Last Post: Scott
0 Turbo Iron 883
Last Post: Ghostdog
0 Need some guidance on installing a traxxion dynamics suspension on my front forks
Last Post: Bryan1976
0 Chinese S&S carbs
12 Crankcase breathing?
Last Post: DJCBlue
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sportster Fork Upgrade
Last Post: Redbeard2
0 Do you use a bike cover?
Last Post: Old Rocker
0 Rear sets?
Last Post: bordens
Last Post: Vic8028
0 Ground Up Beginner Build
Last Post: Paul.W
Last Post: PetesPonies
Last Post: Blackmagellan
0 Clutch springs
Last Post: BigMek
0 Coil polarity
Last Post: Bikeaholic
PEISprotster (68), 2009XR (66), Briank (61), bbj6635 (59), Reddog225 (48), larre1973, Irondrake77 (41), picowatt (40), Jeffrey99 (39), namesnick (39)
efi sportster, engine noise, nightster, pinging
Old 21st March 2010
brich brich is offline
Sportster/Buell Model: xl1200n
brich is an unknown quantity at this point
Default Engine Pinging
I recently put forward controls on my 08 Nightster. In order to this this I had to remove the forward exhaust. I installed a new exhaust gasket, but it sounded like it had a leak. I installed a second new exhaust gasket, the bike sounded a lot better, however I took it out for a ride the other day (first real ride since putting on the forwards) and it sounds like it has a ping coming from the rocker covers. When I accelerate it gets louder and faster, when I pull in the clutch it seems to go away?????? Any help would be appreciated.
Old 22nd March 2010
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
I assume you made no other changes during the install (to something that might effect tuning?).
How about the front 02 sensor, wiring intact and connections tight?
How about the heat shield? Properly installed, nothing loose or damaged?
Old 22nd March 2010
Speedy's Avatar
Speedy Speedy is offline
Speedy is a glorious beacon of lightSpeedy is a glorious beacon of lightSpeedy is a glorious beacon of lightSpeedy is a glorious beacon of lightSpeedy is a glorious beacon of lightSpeedy is a glorious beacon of lightSpeedy is a glorious beacon of lightSpeedy is a glorious beacon of lightSpeedy is a glorious beacon of lightSpeedy is a glorious beacon of lightSpeedy is a glorious beacon of light
I have a 2007 1200L with a D&D Fat Cat 2-1 on it and I experience the same pinging. I work in a Harley dealer with many Harley certified techs and the first time I experienced this I asked them right away. They said it isn't anything that hurts the bike but seems to occurs a lot in FI sportys and they haven't found anything that truly fixes the noise yet. This was about a year ago. They said it was nothing that was hurting the bike either. I just left it alone my bike has been running just fine since I asked them about it.
Old 22nd March 2010
whittlebeast's Avatar
Other Motorcycle Year: 2008
Ping is never acceptable.
This is a fine example of why I never trust dealers. The detonation is a combination of the stock o2 feedback loop in the ECU is absolute junk. The bike has way too much timing in the midrange. These bike do not have enough cooling so you have to run them somewhat fat or around 14.0 AFR at part throttle.
Lots of people throw loud pipes on it and wind up just not being able to hear the motor trying to melt down. Power commander just throws butt loads of fuel at them.
AW
Old 22nd March 2010
Anaxios Anaxios is offline
Sportster/Buell Model: XL 1200L
Anaxios is a glorious beacon of lightAnaxios is a glorious beacon of lightAnaxios is a glorious beacon of lightAnaxios is a glorious beacon of lightAnaxios is a glorious beacon of lightAnaxios is a glorious beacon of lightAnaxios is a glorious beacon of lightAnaxios is a glorious beacon of lightAnaxios is a glorious beacon of lightAnaxios is a glorious beacon of lightAnaxios is a glorious beacon of light
Default Could it be the fuel?
This is only hear-say, but refineries supposedly used to put more volatiles in their mix during the winter for easier starting, at least back when all vehicles had carburetors. Anyone caught with a tank of winter gasoline on a warm spring day might hear some pinging from the more volatile fuel.
My knowledge is not the most current, but if gasoline is still blended that way, the weather could explain your problem. Did you fuel up immediately before the road test? I really hope its as easy as that for you.
Old 23rd March 2010
Speedy's Avatar
I appreciate the insight. Thank you very much for saving my engine.
Old 23rd March 2010
Recon Dad Recon Dad is offline
Sportster/Buell Model: 1200L
Recon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura about
I agree with Whittlebeast.
Make sure that that the four nuts that hold the exhaust pipes to the cylinder heads are torqued properly. A lot of people tell you just hand tighten them and then you end up with exhaust leaks and poor performance.
Patriot Guard Rider Pa. Ride Captain
2009 Heritage Classic Softail, 2008 XL1200L
Old 23rd March 2010
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
I'm not surprised to hear a rubber mount pings. If the stock plugs are equivalent to NGK 7, with 9.7:1 I'm not surprised. My bike has 10.5:1 with pretty good chambers, and mine pinged like a biache with 7's. 8's were a lot better but still had a little. It took 9's to get it to stop.
I also agree stock Sportsters have too much advance in the ignition curve, and run too lean.
Old 25th March 2010
I have new fuel in the bike and the exhaust nuts are nut. I am however going to change out the plugs. I was talking to a buddy of mine and he also mentioned something about the plugs, so I will try that.
Old 25th March 2010
Biknut which spark plug do you suggest
