0 Chinese S&S carbs
8 Inexplicable miss
0 Bandanas
0 Top end failure
Last Post: Mission1
0 XR mutt race bike progress
Last Post: Scott
5 Eye Protection When Riding?
0 Ignition advice
Last Post: Rhode Warrior
0 1992 XL ignition explained
Last Post: Bwf347
0 New guy from IL
0 normal shifter shaft wobble
0 Front Brake Upgrade
Last Post: keithnh
0 Info needed on mini sumps.
Last Post: Randy_rots
0 Coil readings
Last Post: Billy1200
0 3/4” Axle Drum Brake ??
0 Inherited Ironhead
Last Post: Akdawg
0 Noise and rod play
Last Post: Vic8028
View Poll Results: What weight fork oil do you use
5w 40 9.62%
10w 87 20.91%
15w 115 27.64%
20w 40 9.62%
30w 16 3.85%
standard weight HD 76 18.27%
Screamin eagle HD 52 12.50%
Multiple Choice Poll. Voters: 416. You may not vote on this poll
Old 15th July 2005
lthj75's Avatar
lthj75 lthj75 is offline
lthj75 has disabled reputation
Default Poll: What weight fork oil do you use?
Anyone ever try 30W? How much of a difference does it make?
Old 15th July 2005
gronk62's Avatar
gronk62 gronk62 is offline
mostly harmless.. (sssm)
gronk62 has disabled reputation
I've tried various weights but the one that feels the best for my riding style and the roads I ride on is 15w.
I found 20w to be a bit to harsh so I would imagine 30w to be over the top
Old 15th July 2005
The_Bishop's Avatar
The_Bishop The_Bishop is offline
Sportster/Buell Model: 1200XL Custom
The_Bishop has disabled reputation
Yikes - 30W would be like having no front suspension at all.
I think the general concensus is 15W Bel Ray.
Old 15th July 2005
tonyhds's Avatar
tonyhds tonyhds is offline
Sportster/Buell Model: NRHS 1250 C
Other Motorcycle Model: Road King Classic
tonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of light
Bel Ray 15W
04 Road King Classic
04 NRHS 1250 Custom - Longhorns Orange
10.3-1 Flat tops, Stage 2 heads, Powdercoated black w/ highlighted fins, SE 497 cams, TC88A ignition w/ a custom Map, 2" HurricaneFlow intake, 1200 gearing, Energy One clutch, Progressive 418's and Progressive front springs, Mustang Vintage and loves oil.
aka " The Guzzler "
" A song needs to breathe. The rhythm needs to breathe. Sometimes the best way to get some punch out of something is to slow down right before you hit it. Kind of like a slingshot --- Pow "
SRV
Old 15th July 2005
daesdaemar's Avatar
daesdaemar daesdaemar is offline
Sportster/Buell Model: 1200 XL Custom
daesdaemar is on a distinguished roaddaesdaemar is on a distinguished roaddaesdaemar is on a distinguished road
Bel Ray 15
Old 26th May 2007
07sporty's Avatar
07sporty 07sporty is offline
Sportster/Buell Model: XL1200Low
07sporty is a jewel in the rough07sporty is a jewel in the rough07sporty is a jewel in the rough07sporty is a jewel in the rough07sporty is a jewel in the rough07sporty is a jewel in the rough07sporty is a jewel in the rough07sporty is a jewel in the rough07sporty is a jewel in the rough07sporty is a jewel in the rough07sporty is a jewel in the rough
I really need to change to fork weight on my bike...what weight is the stock fluids...and it seems like most suggest 15w???
2007 XL1200 Low Black/ White
Drag Bars w/ 6" risers
V&H Straightshot S/O
S/E ac..&..SERT
Foward Controls
10" Licks Shocks
Badlander Seat
Old 26th May 2007
WinXP WinXP is offline
Sportster/Buell Model: Night Train
WinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enough
Bel Ray 15
06 Night Train
95 1200 Sportster
04 1200 Sportster
09 Dyna Street Bob
Old 26th May 2007
XLXR's Avatar
XLXR XLXR is offline
Go to the various websites of aftermarket oil makers and see what they recommend as equivalent to HD recommendations. www.amsoil.com is the only one I know, but I don't remember what they recommend. I went from stock to 20 to 10 to 5 and back to 10, along with many other changes. If you have to use 30 w, your springs are probably too light, or worn out, for your weight.
Old 26th May 2007
XLXR's Avatar
This poll is rather interesting. I weigh 230 - 260 lbs, depending on what gear is in the saddlebags. Probably heavier than most other guys. Yet with my forks set up as I describe below, the initial rate of my forks are softer than lighter weight guys, yet the bike handles better. So far, I am the only one using 10 w fork oil.
What I actually did was make the foks softer and softer until they were so soft the front tire would bounce and chatter over rough bumps. Then I stiffened them up just enough to get good dampening under all riding conditions and throughout the fork travel.
If you compare my spring rates to the Progressive progressive spring, the inital rate is softer and the final rate is harder. I think this is one of the keys to getting the Roadster to handle well. Because of the odd weight bias of the bike with rider on the bike, most of the rider weight ends up on the back end, therfore, heavier riders need lighter initial spring rates in the front. Opposite anything I have ever come across before.
Old 26th May 2007
xllent01's Avatar
xllent01 xllent01 is offline
Sportster/Buell Year: 01
Been running SE 20W up front for the stiffer ride that appeals to me from years of racing, bike handles just fine even with the 3* Mid-glide conversion up front, no wobbles, wanders, or shakes. just tracks straight and true.
RTFS
Ride That F'N Sportster!!
