0 THE Trainspotting Thread
0 Identity crisis
0 1970 sportster overload
Last Post: maltesefalcon
0 1275 cams
0 Mikuni VM38-9 on Kickstart Bike?
Last Post: 45Brit
0 front brake line help - 1980
0 90XLH Hugger Forward Control Help/Install Questions.
Last Post: Rollbar
0 Tires & Shocks Needed: '90XLH 883
Last Post: Rollbar
Last Post: sprink
0 Newbie seeks smoother ride
Last Post: 45Brit
0 Has anyone replaced rubber floorboard dampers?
Last Post: Jerry P
0 Rear fender spacers?
0 Secret Australian Business
Last Post: fernf5
0 Boots
0 1969 XLCH Shifter Issues
Last Post: randy3934
0 Oil Cooler installation on an early Ironhead
0 Tire recommendations?
0 New guy here from Michigan
0 "S" model specific Q&A
Last Post: Agave
0 1968 ex barn dweller thread
Last Post: fernf5
0 Front shock upper bolts
jmull, greyfang (74), mhowers (64), 9fingerkustomz (56), gm0uzm (54), 75oldschool (54), hog rider (54), avnsteve (51), BlaquePatton (45), dsonoma (42), Reverend (39), cormschr (39)
Old 1 Day Ago
mikethebike61's Avatar
1970/71 USS ORION we had an EM-2 named MIKE BOWERS....steroid freak who stood about 5'6" with 20" biceps and looked like you pumped 10 PSI of air into him.....
To test for A/C he would put his elbow on ground and bounce the back of his hand on the terminal.....saw him do that o a 440 vac power buss on a $100 bet
I don't recommend that...
Old 23 Hours Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
No brain. no pain ?
I don't juggle knives and I don't play with electricity. Or anything else I don't understand.
Old 21 Hours Ago
i believe it.i wouldn't want to try it with 220 vac.turns ratio= half the voltage twice the amperage.
