0 THE Trainspotting Thread
0 Identity crisis
0 1970 sportster overload
Last Post: maltesefalcon
0 1275 cams
0 Mikuni VM38-9 on Kickstart Bike?
Last Post: 45Brit
0 front brake line help - 1980
0 90XLH Hugger Forward Control Help/Install Questions.
Last Post: Rollbar
0 Tires & Shocks Needed: '90XLH 883
Last Post: Rollbar
Last Post: sprink
0 Newbie seeks smoother ride
Last Post: 45Brit
0 Has anyone replaced rubber floorboard dampers?
Last Post: Jerry P
0 Rear fender spacers?
0 Secret Australian Business
Last Post: fernf5
0 Boots
0 1969 XLCH Shifter Issues
Last Post: randy3934
0 Oil Cooler installation on an early Ironhead
0 Tire recommendations?
0 New guy here from Michigan
0 "S" model specific Q&A
Last Post: Agave
0 1968 ex barn dweller thread
Last Post: fernf5
0 Front shock upper bolts
jmull, greyfang (74), mhowers (64), 9fingerkustomz (56), gm0uzm (54), 75oldschool (54), hog rider (54), avnsteve (51), BlaquePatton (45), dsonoma (42), Reverend (39), cormschr (39)
'90, shocks, tires
Old 20 Hours Ago
Rollbar's Avatar
Rollbar Rollbar is offline
Sportster/Buell Year: 1990
Rollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud of
Originally Posted by xHDrider View Post
I run the optional bigger metzler me 880 tires
i use road king air shocks short ones in the 11 inch range same lenght as my stock shocks eye to eye. i use a little harley air pump.
i ride with about 2 psi alone an with a buddy about 12-15 psi more user friendly then a spanner wrench
also have progressive front fork springs, if you ever rode with a front fork brace you wouldnt was to ride with out one (just figured i would throw that in)
Ok great information.
I was looking at those front braces but in Florida losing the front fender might not be an option even if I chopped it down some. But I have really thought about those braces and if they are that good, well,,,,,,,,,,
Thanks again.
Old 19 Hours Ago
rwharris's Avatar
rwharris rwharris is offline
Sportster/Buell Model: 883 Hugger
rwharris is an unknown quantity at this point
Going down from a 48 to a 47 rear sprocket only lowers your rpm by 50rpm. 22-47 at 75mph =3750rpm. I have the belt drive conversion on my 90 and at 65mph I am reving 3300rpm and at 75 = 3950 rpm. I have no options to change gearing. I also have a fork brace( screaming eagle) fits with fender on. I sent you a PM. Roger
Old 19 Hours Ago
Rollbar's Avatar
Ya I ordered a 46 tooth for the rear and I have a 22 tooth for the front.
4spd so I should be ok and might just have to cruise around the back streets in 3rd gear.
We will see how that works but before I put it on, I'm gonna do some calculations.
Wanted to have it so I can do it at the same time as the tire etc.
Old 18 Hours Ago
Rollbar's Avatar
Originally Posted by Rollbar View Post
Here is my bike.
When I bought this bike the POwner painted a lot of it flat black w/grill paint seems like.
Question regarding the mags/Rims.
Did they come black like that it were they all aluminum looking?
The spokes (if you want to call it that) sides were also black and I took a Scotch-Brite pad and made the sides of the spokes to look like aluminum to break up all the black.
Thanks again,
Old 12 Hours Ago
cal43's Avatar
cal43 cal43 is offline
if you search for a real motobiketire and not a chopper/cruiser everlast, search for Bridgestone BT-45
Old 6 Hours Ago
Rollbar's Avatar
Ok thanks,
