0 First Harley ...
0 Magneto insulating block removal
Last Post: Captain Johnny
0 'Floppy' Forks ???
0 Bendix insulator block
0 '69 XLH wiring question
Last Post: sleighcrane
0 Hagerty Insurance
0 Rear mount for solo seat?
0 Thread revival
8 New build - engine ping / gnarly vibration
Last Post: ironheed
0 After years of Japanese bikes I got a sportster..
Last Post: Michman
0 Memphis Shades Fats Drop-Top Windshield
0 77 XLT smokes a lot on start up
Last Post: Kingrabbit
0 Removing oil tank DIY?
Last Post: oldboy
0 Paint Code for 1976 Sportster
Last Post: Parker 1000
0 Adaptive headlight issues
0 86 c I burning pistons
0 Show your bike next to a lake
Last Post: zimbros12
Last Post: jcro61
0 High idle code P0505
Last Post: dayypete
reinhard (65), randolph196 (64), dexter (63), Swamp Fox (63), drewsport (58), paintslinger16 (57), grumpy0868 (52), Prototype (40), Tustan (40), dustom_99 (37)
Old 11th September 2019
sportymike02's Avatar
Sportster/Buell Model: 1200c
Sportster/Buell Year #2: 1979
sportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond repute
Default Removing Front Blinkers
I don't care about doing it the "right" way. Can I just cut & tape the wires?
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud of
You can do that, but you might get turn signal open codes tho. If you're set on doing it, I suggest using heat shrink over the ends of the wires instead of tape.
NLXL's Avatar
NLXL NLXL is offline
I'm not sure if a 2002 model was already that smart in giving that codes(?). Well, if in doubt, just remove the bulbs first and see what happens.
Sportsterpedia
Here's the Sportsterpedia section on Turn Signals:
If you do that, you'll likely get no flash - to address the current expectation of the TSM, you'll need to add load resistors so the TSM flashes correctly...
Remove the bulbs and see what you get...
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
I removed mine years ago, taped and stuck wires under the tank. No problems with the rear blinkers or flashers.
BKB's Avatar
BKB BKB is offline
In some states, if the bike came from the factory with turn signals, it may be illegal to not have them. Might want to check before you remove them.
Old 12th September 2019
I removed the bulbs & hit the switch - rear lights lit & stayed lit.
I guess load resistors & heat shrink tube are in my future.
no mc inspection in NJ so I don't think anyone's gonna notice or care that they are gone
thanks guys
Here in ND, we don't have MC or Automobile safety inspections. If you get pulled over for anything, speeding, noise, etc. the cops will give you an equipment or safety ticket on top of your speeding ticket and require you to get a state inspection from the Highway Patrol. If you don't pass the inspection, they'll take your license plate and return it once you pass.
A lot of times they'll just give a verbal warning so they don't have too much paper work.
Do you feel Lucky?
