0 73 Electric Start won’t run after firing
0 G'day from London, England
0 top end rebuild
Last Post: eisenhead
0 my local dealership closed today
0 1986 Adjustable Push Rod Adjustment
Last Post: 109Countries
0 No Power to hand controls
Last Post: Proteus
0 Regulator/rectifier question
0 Fork oil q
0 1960 XLCH in the UK
0 Fng
6 1983 Ironhead- Final wiring
Last Post: Attaxic
0 My frist question...Fork seal replacement
0 Range With EFI 4.5 Gal Tank
Last Post: jzink0883
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
0 Bean in a can (rattling when accelerating)
14 Buell back in business?
Last Post: 1200CustomHD
0 Bowker Harley Davidson Preston
0 New Harley CEO
0 Knocking in Front Cylinder Until Warm (Before & After Rebuild)
0 Positive news for Harley-Davidson
Last Post: Whitewalls
0 New oil tank
Johnc (74), x750rider (67), bart53 (67), bad rad (66), halfdrive (55), jag1 (48), Zuhaib (36)
doodah man's Avatar
Maybe you could experiment with some thin steel shim stock between the bore and the axle to tighten up the slop?
ferretface's Avatar
Sportster/Buell Year: 1983
ferretface has much to be proud offerretface has much to be proud offerretface has much to be proud offerretface has much to be proud offerretface has much to be proud offerretface has much to be proud offerretface has much to be proud offerretface has much to be proud offerretface has much to be proud offerretface has much to be proud offerretface has much to be proud of
The wear comes from the cam follower spring pushing the cam up away from the trap door and as the cam axle rotates back and forth during shifting it wears away the tower bore.
I see that, now that you've pointed it out to me. The bore becomes egg-shaped.
It'll always wear that area, no matter what 'fix'. Oh well, it took 14K miles to wear it .050", maybe if I angle-mill it, it'll last another 14K...
All of old. Nothing else ever. Ever tried. Ever failed. No matter. Try again. Fail again. Fail better. -- Samuel Beckett
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
I was asking if you'd checked if the shift plate was square to its own shaft. I was always curious if the welds holding the shift plate on distorted it or Harley machined it true after the welding.
Agree the pins have some slop in them. You could shim one side to get the angle you're looking for. Though if you can angle mill, couldn't you slap a boring head in there and try the bushing idea? Lots of 3/4" ID by 7/8" OD bushings on McMaster.
ferretface's Avatar
NOS parts came today. Nice shiny mirror surfaces on the tower bore and the cam.
I spent a couple hours cleaning the preservative off them and disassembling the trans. Put everything back together. Cam plate is now parallel with the fork shaft. Ran through the gears. They all worked.
Took all apart again and put a light coat of grease on all mating surfaces and re-assembled it again. Next will be re-checking all the clearances between gears and then checking and re-shimming the thrust washers for m/s and c/s, if necessary. I don't think they'll be too far off. It was only the first gears that I replaced this time. Now it's all-Andrews gears and shafts, with NOS shifter tower & cam and NOS H-D bearings and springs etc.
I have no idea if it'll make any difference from last Summer. But I'll sleep easier at night.
...If it all works out OK...
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to behold
I fitted all Andrews gears and shafts in my '78 to fix a slipping 2nd gear problem. Trans shifts like butter now with never a missed or slipped gear. Well worth the money in my opinion.
Eric
