0 TC88A makes me smile until WOT
Last Post: broncobob71
0 Moto Guzzi V9 Bobber debut
Last Post: mjptexas
0 fat man on a sportster
0 Fitting 2003 sportster seat to 2004 sportster
Last Post: MudDigger
Last Post: SoonerSport
Last Post: SteveK
Last Post: toe
0 Replacement Fuel line?
Last Post: jordan1200
0 Electrical Problem with '77 XLH-no power
Last Post: Tator
0 Seats
Last Post: Beelzeboss
0 The Harroway: Sefton Warren To Powderham Castle
0 Out of the Box Thinking
Last Post: sltm1
0 Gravydog crashed again.
0 What do you think the wet weight of the Pan America will be?
0 Dead battery cells - 1997 sportster 883
0 Broke fin on head.
Last Post: lynnx
0 1960 XLCH in the UK
Last Post: lynnx
0 mode of failure
Last Post: WI Bob
0 Let's study the 77-85 oil pump, parts, and changes and when.
6 Is Your SPORTSTER...
ziggyhd1 (60), greven (58), bliynd (33)
Old 3 Days Ago
gpcramins gpcramins is offline
Sportster/Buell Year: 2016
gpcramins is an unknown quantity at this point
Default Splitting cases..
I have an issue which requires me to tear my engine down and split the cases. The bike is a 2016 Roadster and has 35,000 miles on the odometer. Is there anything I should replace while I am in there? I'll be doing rings and a valve job since I will have it apart. Valve lifters? I am assuming the cams, transmission, etc. are probably good to go for many more miles...
If anyone here has done this, I'd love to hear your input....
Old 3 Days Ago
lucifer_mr2 lucifer_mr2 is offline
Sportster/Buell Year: 2012
lucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant future
Not that they need the cases split, but cams and clutch should be done. Maybe a displacement and compression increase.
Old 3 Days Ago
Do you suspect your “issue” has had an affect on the primary, charging system and transmission? Or might it be limited to the top end?
Old 3 Days Ago
Bored now Bored now is offline
Sportster/Buell Model: 883
Bored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond repute
So what requires attention? crank or transmission, apart from the cranks in the 04 and 05 bikes the bottom end of the rubber mounts have proved to be almost bullet proof, unless you have used a mls gasket and pulled a cylinder stud? I have a 2013 on the bench this week and will be splitting the cases to install the Buell XB/XR1200 crank, have done it several times, nice and straight forward job, use the drain plug to get the oil out before you split the cases, saves a lot of mess.
Old 2 Days Ago
The stator threads for top screw are knackered and I buggered up a thread repair. Bike has 35,000 miles. This is my fourth stator, first three replaced under warranty. I went aftermarket this time, and will be using non-torx screws.
The first stator died at 16,000 miles. Second at approximately 28,000 miles. This one died at 35,000 miles. Harley tested the charging system and stated everything else was fine.
The stators all fail in the same location, either one or both poles nearest the leads. I knew what it was the moment I saw the battery light. The smell of the fluid in my primary when I dumped it confirmed the problem.
I will be replacing the regulator with a MOSFET type, the battery, and going through all the wiring and connectors. I had a low side a couple of months ago and since I am doing some other work, I figured I would get it all done now.
I also had a wheel bearing failure at 34,000 miles, a clutch failure at 24,000 miles, and a crossover pipe crack discovered when the first stator failed all covered under warranty.
I hope Harley is sending a disclaimer to their international customers before they drink the Kool Aid. When they covered my rear wheel bearing failure, I noted the country of origin for the replacement wheel was China. While I believe the Chinese make excellent equipment, I think the "wanna be hard" types might have a heart attack were they aware of this..
Old 2 Days Ago
Interestingly enough, when the cross over pipe failed, the older guy at the service desk informed me that "Sportsters were not meant to be ridden for long periods of time on the freeway", I wish they would have told me that when I bought the bike. Worked for a mechanic in my teens who toured the country on CB500 back in the seventies...
The more things change, the more they stay the same...
For the record, I really do like the bike, it would just be nice if Harley focused on building bikes rather than selling T-shirts and bumper stickers... Maybe I am just getting old...
Old 2 Days Ago
Subscribing Biker
Back in the 70's, a lot of motorcycle Owner's manuals had a section on Safe Operation and it would say "on extended riding, to stop after an hour or so and let the motor cool for 20min. to a half hour before continuing on. This caution is no longer in the newer manuals. It may apply to Ironheads but I don't think it applies to Evo Sportsters. Still, on a long road trip and temps above 80F, I always stop after an hour or so to let mine cool (in shade if possible) it also keeps me from getting too exhausted.
Old 2 Days Ago
Wow, HD have definitely let you down with those stator failures, there is clearly something else wrong to have repeated stators fail, I would contact HD direct and ask for their assistance, that is not right. I would also be telling HD about the knob who said "Sportsters were not meant to be ridden for long periods of time on the freeway" what a moron, you will come across members here who have ridden their Sportsters over a couple of hundred thousand miles. Contact HD, they can only say no.
Old 1 Day Ago
Glamazon Glamazon is offline
Sportster/Buell Model: xl883r
Sportster/Buell Year: 2014
Sounds like you got unlucky, I have 36.3K on my 883R & all's well. Had a rear wheel bearing go at 26K. Had the upper belt guard break at the shock mount around 17K. I ride all year & had 2 warning display panels & 3 rear brake switches. British winters destroy electrical components, spoke to BMW, Triumph, Honda & Ducati owners with similar electrical grief
