0 Chinese S&S carbs
0 Magneto insulating block removal
0 Down on oil
0 magneto twin plug heads
Last Post: Hornsmith
0 No juice, no run, no power, nothing...
Last Post: BWP 5p
Last Post: ZCarFan
0 Clutch Q
0 Round Air Cleaner Poll
0 Rear wheel alignment
0 fork oil
10 big bore question
Last Post: H.E.L.M
0 Hamburger drum brake clunk noise
0 Pre-ride inspection importance.
0 Does 20W60 reduce cam gear noise?
Last Post: XL Dane
0 Hurriicane
0 TC88A EX lower MAP settings
0 Fun or money?
5 Wet Dream, Ever Have One?
0 Poll: Saddlebag Supports
0 Carb not squirting fuel
Old 31st December 2014
teamcurtis teamcurtis is offline
Sportster/Buell Model: Sportster C 883 (1200con)
Other Motorcycle Model: Ducati Monster 796
teamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to behold
Default Speedometer sizes
Has Harley ever changed the size of the speedometer for the sportster?
I have a 03 custom and want to move the speedo.
Can I just buy the mount off any year that positions the gauge where I want it? Like say a 2010
Folkie Folkie is offline
If you have an '03, why does it say in your details that you have an '02?
because im a bad typer?
ill fix that
csmith72's Avatar
csmith72 csmith72 is offline
Sportster/Buell Model: XLH Hugger
Sportster/Buell Model #2: XLH 1200
Sportster/Buell Year #2: 2002
Other Motorcycle Model: VRSCDX
csmith72 is a splendid one to beholdcsmith72 is a splendid one to beholdcsmith72 is a splendid one to beholdcsmith72 is a splendid one to beholdcsmith72 is a splendid one to beholdcsmith72 is a splendid one to beholdcsmith72 is a splendid one to beholdcsmith72 is a splendid one to beholdcsmith72 is a splendid one to beholdcsmith72 is a splendid one to beholdcsmith72 is a splendid one to behold
00-03 3" 04 up 4"
http://igg.me/at/skully/x/8591694
Is that right? My mate's got an '03 Custom; I thought the speedo looked the same size as the ones on the rubbermounts (4").
csmith72's Avatar
sorry, for 02'
883/1200 custom = 67283-99a (4inch)
all others = 62025-99a (3inch)
Hmmm, the '04 speedos are a different part number (with an '04' suffix), but they are full data bus bikes after all, so I'd expect that they would be different.
However, the 'bracket' (and housing) is the same part number. Eg the '03 Standard, Hugger, and 883R, and the '04 883, all use the bracket # 67053-95.
Therefore the speedos on '03 and earlier bikes must be the same size as the '04 and later bikes: 4".
2002 Speedos look to be:
67025-99A SPEEDOMETER, mph (49st./Cal.) 2002-1200
67037-98B SPEEDOMETER, mph (49st./Cal.) 2002-STD/HUG/883R
67283-99A SPEEDOMETER, mph (49st./Cal.) 2002-1200S
67041-98B SPEEDOMETER, kph (Can./HDI/Aust./Japan) 2002-STD/HUG/883R
67285-99A SPEEDOMETER, kph (Can./HDI/Aust./Japan) 2002-1200/S
67290-98B SPEEDOMETER, mph (Gt. Brt.) 2002-STD/HUG/883R
67284-99A SPEEDOMETER, mph (Gt, Brt.) 2002-1200/S
67283-99A SPEEDOMETER, mph (49st./Cal.) 2002-1200C
67436-99A SPEEDOMETER, mph (49st./Cal./Can.) 2002-883C
67285-99A SPEEDOMETER, kph (Can./HDI/Aust./Japan) 2002-1200C
67416-99A SPEEDOMETER, kph (HDI/Aust./Japan) 2002-883C
67284-99A SPEEDOMETER, mph/ kph (Great Britain) 2002-1200C
67415-99A SPEEDOMETER, mph/ kph (Great Britain) 2002-883C
These are all 4" speedos.
Ranchero50's Avatar
Ranchero50 Ranchero50 is offline
Sportster/Buell Model: 1200 Street Brawler
Ranchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond repute
I was on eBay last night looking at tachs and noticed that some of the BT's had white or silver face gauges, some were in the 4" size.
I also noticed the BT tachs red line lower than the sportster ones. I'd love to go silver or white face on my bike. At $340 the combo gauge is just too expensive to add a tach.
The build thread... http://xlforum.net/forums/showthread.php?t=1821880
I changed the speedo on my '05 to a silver face one, and added the silver face tach:
