0 H4 LED Conversion - write up with photos
0 weld on hardtail
0 Down on oil
0 CV Carb hesitation
0 Mounting seat
Last Post: guidowisozk
0 TC88A EX lower MAP settings
0 Magneto insulating block removal
0 magneto twin plug heads
0 Cosmo's ECM Relocation Mod
0 i want a narrow/standard mustang vintage
5 Wet Dream, Ever Have One?
Last Post: Joe_jeep
0 Round Air Cleaner Poll
Last Post: Joe_jeep
0 Clutch Q
Last Post: wrkdWS6
0 Chinese S&S carbs
Last Post: Hornsmith
Last Post: BWP 5p
0 Rear wheel alignment
cylinder
Old 23rd February 2017
Originally Posted by scoot View Post
The plug wires are the same length, so I was primarily considering the spark leaving the mag. I do not have the stock wires, in fact not much was stock. But in the mean time found the points to be burnt, leading me to believe that the condenser may have a problem. But also found a seized tappet bearing, so waiting on parts, will post back to let ya all know. Thanks
You should use solid wire type plug wires, length (equal or otherwise) on these is not critical.
Burned points is usually the condenser.
The seized tappet bearing is a Holy Crap! moment.
If the roller on the end of the lifter is what you are talking about you have a SERIOUS problem.
You say seized, I have never seen one seize, I have however seen many explode.
If this is what happened you should consider a complete teardown.
When that happens it wipes out the cam and the lifter holder.
The really evil part of this failure is that the little bits of super hard metal that come off the roller and the needle bearings and the camshaft go through the entire motor and spoil it.
The pieces shred the oil pump housing and get pumped into the oil tank where they have the chance to make a return trip through the motor.
The little bits get stuck in the soft piston skirts turning the pistons into sandpaper, dragging up and down the cylinders when run.
The super hard little bits go through all the other bearings in the motor and make little micro injuries that eventually turn into major catastrophic and premature failure.
Old 24th February 2017
Indian Joe Indian Joe is offline
Sportster/Buell Model: sportster 1000
Indian Joe has a spectacular aura aboutIndian Joe has a spectacular aura aboutIndian Joe has a spectacular aura aboutIndian Joe has a spectacular aura aboutIndian Joe has a spectacular aura aboutIndian Joe has a spectacular aura aboutIndian Joe has a spectacular aura aboutIndian Joe has a spectacular aura aboutIndian Joe has a spectacular aura aboutIndian Joe has a spectacular aura aboutIndian Joe has a spectacular aura about
I noticed that on my dual fire ironhead. Put your hand down at the end of the exhaust,feel the differ between the two exhausts. front is running a little warmer. Its the first to foul out too. the rear exhaust ,that is. Will put a little more time on center the points. I think it would be wise to kept a log book for your bike. Everything parts #s,measurements,brands,how it was installed and when. Got me one of those temp gun too. very inexpense, fun.
Old 25th February 2017
Some factory cams have different grinds for the front and rear cylinders.
Center the points cam, this is critical as it changes the spark timing.
Adjust the valves properly, from there it is what it is as long as you have no vacuum leaks.
