Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
0 Stars and spanners?
Last Post: Meghanbrr
0 What Trips Do You have Planned for 2019
0 Starter wouldn't shut off
0 Riding pants repair?
0 Replacement oil pump year 74
Last Post: Brog
0 Can't find where oil leak is coming from. 1200C
0 Basket case
Last Post: bill smith
0 1968 xlch
0 Howdy From Texas
0 Help Identifying Pistons
Last Post: Staffords
0 Slip on muffler
Last Post: Joe_jeep
0 Boring intro
0 Just installed 70900274 combo gauge - fuel light stuck on
0 Down on oil
Last Post: Billy1200
5 Wet Dream, Ever Have One?
Last Post: Joe_jeep
0 Tach/speedo
0 73 XLH For Sale, what's it worth
Last Post: RoadsterMike
0 Chain drive conversion for 100+ horsepower??
Last Post: wrkdWS6
0 Nothing to See/Hear
0 p1352 error code
0 AFT Returns to Indy Mile During Indianapolis 500 Weekend
duckster (70), 1ST_SPORTY (67), stein (58), tanksgt (51), tompie (47), eness76 (44), watsone020 (42), bohagon (32)
Old 21st November 2006
Moved On Moved On is offline
http://www.sportster.org/tech/evo-tech/heads.shtml
Originally Posted by sportster.org
In 2003, Buell came out with the "XB" head. Same size valves ...
If you go the XB (silver) route, you'll also have to mill/drill/tap your breather holes, the XB heads have the bosses but they're not prepared because the XB breathes out the top of the rocker box.
I guess that doesn't shed any light on the PCV question though.
Here's a blast picture:
The page I got that pic from (http://bcrider.com/buell.html) says the Blast vents into the carb.
And here's an interesting thread where Buell owners are talking about XB vents going into the carb:
http://www.sporttwin.com/Forums/viewtopic/p=3647.html
Gazza
rottenralph's Avatar
one more time around for a good explanation of whether it is a pvc or just an an fitting.
cjburr's Avatar
cjburr cjburr is offline
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2009
Ralph I called the Buell dealer and the black thing at the top of the head is a PCV valve. He said Buell went with that configuration to prevent oil blowing out into the intake like it does on the Sportster. They cost $8, I wonder if it could be plumbed into the system on the Sportster ??
Do I win a prize ??
My Other Toy Goes Mach 25
You win a prize. I am going to try it because the Jet heads I have are not breather heads and before I have them drill the holes I thought I would look for other options. I really like the idea of having pcv on the top cover. fortunately I have a cracked one here to play with and figure out where to put it. This is what I love about this site. I got an answer to a question that many have probably asked themselves. I just added one other thing to my list of projects this year. Thanks to you CJ I am also going to have to put on inverted fat forks. They look too good on your bike for me to skip it.
cjburr's Avatar
If the rocker box covers will fit on your heads, and I don't see why not, it should work. Where are you going to route it, to ambient or into your intake tract somewhere ??
Just finished my bobtail fender install but no pics, the wife took the camera to Georgia.
chrishajer's Avatar
Sportster/Buell Year: 1988
They vent through the rocker box, not the head, through that PCV valve. Then they dump into the airbox, just like the XL. The airbox juts happens to be up, not on the side. The EPA won't let anyone vent crankcase fumes to the atmosphere.
You can put XB rocker boxes on your bike and use the same style breather. I see you are going to try to modify yours, since one is cracked. You can do that too.
--Chris
I am going to play with my broken cover and figure out how I can vent to my filter in the back. If it does not work I send the heads out to have the breathers drilled and tapped.
chrishajer's Avatar
Or just get XB rocker boxes. More money that way though.
--Chris
Old 22nd November 2006
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
So it is a PCV valve! Cool,
If you could find an exceptable way of applying some vacuum to it that would be great !!
It took a while Ralph but you got it
Old 2nd January 2007
TREADMARKS TREADMARKS is offline
Sportster/Buell Model: XB12X Ulysses
Sportster/Buell Model #2: HD Supercharged FXSTBI
Sportster/Buell Year #2: 2005
Other Motorcycle Model: XR650LSM Motard
TREADMARKS has disabled reputation
Buell XB heads vent through the valve covers. Both covers are routed through a check valve, then penetrate the bottom of the airbox base. They protrude about an inch from the airbox base and are located inside the perimeter of the air filter. They can be quite messy if you wind it up alot. American sportbike makes a open air box kit, that has a vent relocation kit to remove the vents from the airbox and move it to a catch can or remote breather.
01XR650 Motard
05HD Supercharged Nightrain
06 XB12X Ulysses
