0 Ultima reprogrammed with Dyna curves
0 ignition switch?
0 New England 2018
0 Another afflicted SE A/C setup
Posted On: 59 Minutes Ago
Last Post: toe
0 65 CH barn find/survivor
0 nightster 1200 Backfire or pop through intake when cold start
Last Post: jhead013
Last Post: Crash7557
Last Post: Bone
Last Post: 1Scooter
0 Weekend at Jester's
0 Look Ma - No Hands - BMW
0 DMT ... anyone?
Last Post: tigger
0 Keith Black 10:1
Last Post: Scuba10jdl
0 mode of failure
Last Post: The Crusher
0 touchy feely sissy bar emotions poll
0 hello and help (Mid Pegs Setup)
0 Hello from Northampton, England!
0 New from Pasco, Fl
0 S&S Cycle Hooligan 2-2 Exhaust
Last Post: Screw Loose Dan
5 Stupid points and timing questions.
0 Chrome or Dark Custom
Last Post: RussW
0 Proposed clutch spring improvement0
Last Post: Serious Blac
moe (74), Playtoe (63), shanneba, Charlie Allen (59), the cowboy way (59), P-Diddly (56), Utahsporty (55), evo-pete (54), stf420 (53), NevadaRob (51), Punisher (49), Razor_Reznor (44), Paycheck (41), jfs92579 (39)
Old 16th March 2018
Heff's Avatar
Heff Heff is offline
Sportster/Buell Model: Xlh
Heff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of light
Default Bent rear hub and questions
So I recently noticed a new problem with my bike. I noticed my new chain was very tight for half a rear wheel revolution, and very loose for the other half.
First thing I did was check that the wheel was centered in the swing arm. I measured the distance from the center of the axle to the back of the shock stud and evened every thing out, and that didn't change anything, and it wasn't even off to begin with. But I took the time to ensure it was good.
Then I installed another new chain. Same thing.
Then I pulled the pinion cover, thought maybe something mysteriously got bent in that area. Nothing.
So i started looking harder at the rear wheel. The sprocket and drum aren't as true as they could be. But. When looking at the gear from the back of the bike the up and down run out is all to hell. So I spin the wheel, and noticed the left side of the hub flange is very, very bent. I never saw this problem at any time I had the bike apart or reassembling. I did hit a big big pothole the other night and immediately felt a vibration. I spun the wheel the next day and noticed it as bent, like the rim itself. But I didn't ser the issue with the chain at that time. How in the world does a hub get bent?
Anyway...
Now I need a wheel, or a new hub. I have aluminum boranni wheels, and want to keep them.
So...a new hub is way cheaper than a wheel. My spokes are clean, can I reuse those? I'd be having the wheel trued anyway. They aren't rusty. They arent broken. And none are bent. I'd prefer to reuse them also to keep things from looking brand new.
77 xlh. Some mods...some visible, some unknown
Old 16th March 2018
brucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant future
if this damage is from a pothole,the rim took most of the hit.check that out closely once it's stripped down.
Old 16th March 2018
Heff's Avatar
After measuring and staring at sprockets and new chains and thinking and measuring stuff again...
It's my brake drum. The drum itself is round. But the part of the sprocket where the chain rollers sit isn't. They're almost 2mm deeper for half of the sprocket. So when that part rolls around the chain gets tighter. The other half of the sprocket comes around, the chain goes slack.
The left side of the hub flange is bent. But doesnt seem to have any ill effect on anything. The right side of the hub is fairly true, at least when it's in a truing stand.
This drum is after market, but fairly new, with no excessively worn teeth. The teeth actually look very been with a flat tip and no shark finning. A friend of a friend has a good used drum to sell me cheap, so hopefully that will get me rolling.
Old 18th March 2018
Ferrous Head's Avatar
Sportster/Buell Year: 1962
Sportster/Buell Year #2: 1966
Other Motorcycle Year: 1966
Are you using the correct brake drum bolts ?
These are shouldered bolts designed to fit snugly into the drum. If you stick ordinary bolts in there the drum can move around.
Old 19th March 2018
Heff's Avatar
I do have the correct bolts in there. It was the drum, or ring gear, or both.
I got an oe drum from a friend, and took care of the problem. So I got to ride today for a few hours with 0 issues. This bike feels so good, it's gonna be hard to part with
Old 19th March 2018
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Model #2: Xl 883n
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Why do you have to part with the bike?
Ok, now I'm revived
Old 19th March 2018
Heff's Avatar
I don't. I was gonna get something for me and my gf to ride together.
But you know...a cobra seat and 11" shoveledhead fx shocks are getting to be the lesser of the pains in the ass
Old 19th March 2018
So the GF has to go ?
Old 20th March 2018
brianbbs67's Avatar
I have been revived
Well, if she hasnt ridden before, she won't know the diffence in ride of a BT. Ignorance can be used to advantage. If not doable, get another bike that you both ride and keep the Sporty for you.
