0 Color
Last Post: Beazer
0 Transmission help!!! tire locks up downshifting!!!
5 Your stomping grounds
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
Last Post: TomD
Last Post: northshore
0 Hello from Kentucky
0 Modding time!! Biting the Bullet
0 Gaskets & Rubber
Last Post: ericfreeman
0 Lowboy frame conversion
124", jörgen karlsson, s&s-cycle, sportster, supersportster
Old 28th March 2013
Jörgen Jörgen is offline
Bike Builder
Sportster/Buell Model: S&S XL124" streettracker
Jörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond repute
Default 124" 1993 XLH build thread.
Hello.
Today the main parts for my 124" engine arrived from S&S to my friend Charley Karlings workshop http://www.karlingracing.com/. Therefor I thought it would be about time to start the build thread here.
Special thanks to Steve Rominski at S&S for making this build possible.
We are still waiting for the flywheels. But with the parts received today, Charley and I can start a lot of actions. Charley Karling can start combustion chamber design, ordering of pistons and varios other parts. And I can start up the frame modification together with UCC (http://www.uccycles.com/), bringing the empty motor as a mock up together with my frame to their workshop.
This will be a 0-7000rpm S&S Delphi EFI street engine. Built for drivability and longevity in mind, not all out maxpower.
Main spec:
  • 4 3/8” bore with a 4 1/8” stroke. (145 Tribute bolt pattern)
  • 8” Carrillo rods (already ordered) with .927" pin diameter
  • S&S B2 heads machined for S&S/Delphi injection and S&S electric compression releases. Combustion chamber designed and machined by Karling.
  • S&S SA cases with max deck height (1" over stock) and machined by S&S for crank position sensor. Fitted with piston jets by Karling.
  • S&S press fit flywheels with BigTwin 1 1/4" sprocket shaft and spread limiters
  • Crank pin will be Karlings own press fit design, Uddeholms steel, BT diameter.
  • Angle squish dome pistons designed by Karling
  • S&S 2 1/16" Dual Bore SA Throttle Body with tuned induction intake.
Today I got this unpacking pic from Karling.
Large pic:
http://www.sporthoj.com/forum/attach...7&d=1364478587
Old 28th March 2013
beuz's Avatar
beuz beuz is offline
Sportster/Buell Model: SPORTSTER "old boy"
Sportster/Buell Model #2: SPORTSTER CR (sold)
Sportster/Buell Year #2: 1998
Other Motorcycle Model: Suzuki GSF 650 Bandit
beuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond repute
What a monster !!!
You live more in 5 minutes flat out on a bike like this than most people do in a lifetime...
Burt Munro.
Old 28th March 2013
Sleeper Sleeper is online now
Sportster/Buell Model: XL883R
Beautiful!
I wish I had your skills and bank account.
Old 28th March 2013
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
This should be something!
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 28th March 2013
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Way kool...Looking forward to the end result!
Old 28th March 2013
Bike Builder
Originally Posted by beuz View Post
What a monster !!!
Originally Posted by Sleeper View Post
Beautiful!
Thanks. Anders "Charley" Karlings expertise is indispensable for me in this project. It was when he showed interest in this build, that it started to get serious. In fact, when I brought up the idea of using the S&S 4 3/8" bore top end parts into a EFI XL design, he reveiled that he had been thinking the same thoughts for a while. That made me confident enough to start the project. Especially since Karling has the knowledge how to design and build a sportster lower end that will handle this 4 3/8" B2 top end.
Among other things, Karling builds his own brand supertwin engines.
This is a film showing such a 4-cam nitro engine. Unfortunately he is speaking swedish in the film. The engines and Karling solutions have been on the PRI exhibition.
This is an animation of the main parts of Karlings Supertwin engines. Using swedish Uddeholm materials.
So my own knowledge and skills is by far not sufficient for this engine project. It's a cooperation project together with S&S and the Karling Racing Engines (S&S dealer).
Karling will produce most parts in his modern shop, using Ironcad and CNC.
The whole package, design etc will be kept together by Karling. Making it possible to produce more 124" S&S/Karling XL-engines of this design, if someone shows interest.
Old 28th March 2013
Amazing!!!
Old 28th March 2013
Bike Builder
Amazing!!!
Originally Posted by norseXL View Post
Subscribed!
Thanks all of you.
Me too, I'm very excited and happy now. Finally this project can enter the interesting phase.
Old 28th March 2013
DonChicago48's Avatar
DonChicago48 DonChicago48 is offline
DonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of light
Should make something well north of 160 HP
Murphy's Law applies.
The 9 scariest words in the English language: "I'm from the government and I'm here to help."
Old 28th March 2013
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
So, will you be done to May and come with me to the Sportster meeting in France
Tore
