Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Suspension, Frame, Forks, Fuel Tank, Oil Tank, Fenders
8 Crankshaft Failure
0 Rear wheel alignment
Last Post: v3ko123
0 wavers
Last Post: ronccc
0 Need help with turn signal and tail light connections
Last Post: keys79
Last Post: Sasnak75
5 Harley T-Shirts
Last Post: Kbetts
0 HELP Identify These Headers Please
Last Post: FiftySixer
Last Post: Tipofthelake
0 1275 Hammer Kit Died
0 Front Master Cyl rebuild question
Last Post: PetesPonies
0 Remember these?
0 Sissy bar with HD quick release bracket
0 Basket case
Last Post: bill smith
0 Cv carb jetting
Last Post: mikethebike61
0 Buell Blast headlight compatibility
Last Post: apotheon
0 Down on oil
Last Post: Billy1200
0 Tappet Block Cover Logo - Recognize?
Last Post: canoli
0 Coil Resistance Question
0 900cc Cylinders
Last Post: Nitro57xl
1911Bronco, Blackbird (82), thai808b (65), Nathan71 (51), lucky-13 (49), Barndog (47), discobanjo (43), albana (41), pat5150 (36)
Old 22nd September 2019
Hornsmith Hornsmith is offline
Sportster/Buell Model: Blast
Other Motorcycle Model: Honda CB400 rat
Other Motorcycle Year: 1980
Hornsmith is an unknown quantity at this point
Default Ulysses Oil Fittings?
Hello everyone, quick question on the swingarm's oil fittings. I'm building a Blast and I swapped the swingarm for an 2006 Ulysses swingarm. I'm still using the Blast's oil tank frame for the oil, but decided I want to use the Uly swingarm as an auxiliary fuel tank, or store water in it while in the Backcountry. So, I need to plug up the holes for the oil lines. I know the drain plug is 1/2" 20, but I can't seem to figure out what the other fittings are. I assumed they were some sort of NPT and looked like maybe 1/4 NPT. I picked up some 1/4 NPT plugs, and while the pitch seems the same, the 1/4 NPT is definitely too thin to properly seal the hole. I looked up other NPT and found that 3/8 has the same pitch and is a bit wider, but when I picked up some, the 3/8 NPT is a bit too wide.
So anyways, does anyone know what the proper size plug would be?
2002 Buell Blast
1980 Honda CB400t
Blasting around the garage, and soon, the streets!
Davo_137's Avatar
Davo_137 Davo_137 is offline
Have you tried BSP or BSPT?
Old 14th October 2019
I didn't try those, I just didn't want to sort through it all, considering it'd still not be certain whether it works. I measured the width of the bolt very carefully and decided it was most likely 9/16". I also knew that the treads where 18s because they matched the npt fittings. I just received some 9/16 18 bolts and they fit perfectly. Problem solved ��
