0 Is this 1200R worth $4500?
Last Post: tvon
0 In Tank Oil Filter?
0 which plug for dual plug heads
Last Post: JonesL
Last Post: Kbetts
0 Accel shafts?
Last Post: kmul
0 Winter reading........
14 DEAR Harley Davidson,
Last Post: Bama Lee XLC
0 How many helmets?
0 ***DK Custom Products Outlaw Permanent HiFlow Reusable Oil Filter***
0 DK Custom Products Streamliner Bullet Turn Signal Relocation Kits
0 ****DK Custom Products Is Now Offering The Power Vision****
Last Post: maverick31210
Last Post: 83ironman
5 Jiffy Standing
5 Oil pump pressure
Last Post: longride
  #1191
cycowrencher's Avatar
Stock: 12 lbs. 17 3/4 in pivot to rear most axle position.
+4: 21lbs. 20 1/4 in pivot to rear most axle position.
+10 (jcros): (40+ lbs)on bike... 27 1/8 in pivot to rear most axle position.
+16 (New arm): 12.4 lbs. 33 3/4 in pivot to rear most axle position.
Sent from my LG-LS993 using Tapatalk
Old 5 Days Ago
Started tear down...
Old 5 Days Ago
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Talking
Sweet, whats your new w.b. going to be? Going to need a looooong chain !
Old 5 Days Ago
Im 66.75 now. I have to go a minimum of +4 just to run the new arm so I will probably make it an even 72. We do not have a wheelbase limit in the classes I run out here. Probably also going to drop rear to a 46 or 44. That will help shorten chain.
Just eyeballed it all up...
69.5 minimum with buell s3 trees.
71 is roughly middle of adjuster range.
73 is max with chain still having adjustment room for stretch...
Old 1 Day Ago
madnss's Avatar
After a year of messing with the super d carb it all came down to running a two step to get the carb to hold rpm. Pretty excited
Old 1 Day Ago
madnss's Avatar
https://youtu.be/37NNloLal78
I’m only light years behind xldukes and mac haha
Old 1 Day Ago
Vohnsen Vohnsen is offline
HELL YEAH
https://www.youtube.com/nikolaiownz - Homemade dragbike with Stock XL1200 '98 engine.
Old 22 Hours Ago
Tinz's Avatar
Tinz Tinz is offline
Sportster/Buell Model: X1
Tinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant future
Now yer set
Old 22 Hours Ago
Tinz's Avatar
Originally Posted by Tinz View Post
Well said Mac. I could probably drop a few more on mine.
Stiffened up the chain guard as well with a high speed sprocket cover.
Next is to tackle the tank shell, going to make a good mold and make a fibreglass shell. Should shed a few pounds from the steel shell.
Got rid of the steel seat pan, going to paint this black, should blend well with the fender and add support.
Should save a pound from the old harness.
Ordered aluminum bungs to make another oil tank, should save a couple more pounds there.
The battery will be the biggest weight savings. 11 down to 3.5 pounds.
Should all add up to a tenth quicker this season.
Old 20 Hours Ago
madnss's Avatar
Noice!!!!!!! 💪🏼💪🏼💪🏼
