0 900cc Pistons
0 Help!!!
0 Oil amount
Last Post: Turbo Sporty 48
2 Your daily tunes...
Last Post: RDHenley
Last Post: ivanford
0 88ci Sport Rod
0 Stock pipes
Last Post: DéDé
0 Proper XLCH
Last Post: rocketnorton
2 Humble pie
0 A Day in the Life...
3 2005 XL883 Standard for sale
Last Post: SLW210
0 The last of a dying breed...
0 '81 Gasket/Rebuild Questions
Last Post: Andy Hog
dave (71), Miami (70), MnKevin (65), bigdogbark (64), robby269 (60), larry p (58), MadDogXR, kev883 (56), 0ut1aw (56), Nu Viking (54), dlclark804 (51)
  #61
Old 13th August 2014
rocketmangb's Avatar
I would tend to listen to a guy with a 170 MPH Sportster !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
maru's Avatar
maru maru is offline
Sportster/Buell Year #2: 1996
maru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud of
Originally Posted by ol38y View Post
Rubine, IMO, the collector is the most important part of the Burns design. You can buy just the collector from them and build the rest yourself. Then you can play with longer primaries as well. Just a thought.
I will second the vote of confidence on the Burns merge collectors and they are a good supplier of the tubing for the rest of the system as well. Systems made with their raw materials are often a work of art. They make good racing mufflers as well, but for sure their merge collectors are very special.
Old 19th August 2014
rubine's Avatar
rubine rubine is online now
Sportster/Buell Year: Bits
Other Motorcycle Model: '00
I may get the merge collector from Burns, but as for the tubing - any material I get from Burns has to be shipped and duties paid on it so I may have to source here in NZ. Can you guys recommend a grade and wall thickness of tubing to use?
Old 28th May 2016
rubine's Avatar
Any votes for thickness of tubing? 1.2mm or 1.6mm 304 stainless steel
Old 16th December 2019
rubine's Avatar
Interesting video with a good example of reversion
Old 17th December 2019
rubine's Avatar
rubine's Avatar
Started playig with shapes and twists, keeping it to Burns spec usung the green string in the pics. Has lengths marked on it with knots. Finding out I like 1/8 pie cuts. Can bend and twist. CLR66mm. Using pipe clamps to hold the pieces together. Drilled holes in the pipe clamps as a visual ref for positioning, and can spot weld where the holes are.
