0 1960 XLCH in the UK
Last Post: lynnx
Last Post: robbie202
0 03 xlh 88"
Last Post: splineman
0 Suzuki Lights On 883
0 If I Could Build My Perfect Roadster...
0 Happy Birthday wandrur!
0 Motorcycle oils or not ?
Last Post: Tucsonmax1
0 modifying to metal oil tank.
0 It's ~Grind~'s Birthday!
0 Tires?
Last Post: jordan1200
0 Jagg offset oil cooler #4700 removal?
0 What engine oil do you use?
Last Post: Crosshairs
0 Hello xlforum
Last Post: big andy
0 Hello From San Diego
Last Post: big andy
9 Aftermarket Petcocks
0 35mm Kayaba Fork Disassemble
Last Post: 1Scooter
Last Post: jammantoo
0 Another spark plug question...
0 Let's study the 77-85 oil pump, parts, and changes and when.
0 Might as well join I guess...
Last Post: Island Dude
0 brake upgrade (Can't Bleed)
Last Post: Caustic Dick
Papatony, chedd (73), Nevar (68), nrbase (66), Smokin-Smitty (61), kbfarkas (59), Irondreads (49), Tim97509 (48), CCM0021 (47), wandrur, bikerusn5 (35)
  #791
Chuckthebeatertruck's Avatar
Chuckthebeatertruck Chuckthebeatertruck is offline
Senior Master Bike Builder
Sportster/Buell Model: Xlh
Sportster/Buell Year: 1959
Sportster/Buell Year #2: 1969
Other Motorcycle Year: 1969
You are not going to find any clear hose that will take the heat.
Probably best off with some sort of teflon hose.
Copper tubing would be cheaper and easier to work with.
Yeah, you will.
https://www.fluorostore.com/collecti...iant=458719653
It's only rated to 450 continuous degrees farenheit.
But it is "some type of teflon hose" -- sorta.
Personally, I consider cutting a bit of soft tube with a pair of shears and screwing down a clamp to be easier than running copper lines.
You may also contact an aviation company. Many will supply FEP line in just about any color you want.
Originally Posted by mrmom9r View Post
One compression ring means that ring has to do the job of 2 when it comes to carrying heat away from the piston, i.e. it's going to grow more.
There's no measurable performance difference between .010" and .020" so make sure you have plenty.
I couldn't agree more.
The only thing I've ever noticed is that when I've gone closer to .030, my low speed oil consumption increases about 25%. But, I've never broken rings -- even when severly overheating a motor.
Trade offs . . .
RKN's Avatar
RKN RKN is online now
Sportster/Buell Model: 883 (90")
RKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to all
Thank you, Chuck!
SLW210's Avatar
SLW210 SLW210 is offline
SLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to behold
There are clear hose options. https://www.mcmaster.com/
Just search for clear hose. some from sub-0° to 500°f
