Last Post: ronccc
0 Ironhead Exhaust Poll
0 Do not buy this oil!
0 WTS: Forward Controls 2004-13
0 New Harley CEO
0 Vulcan Mid Glide Triple Tree Conversion Set
Last Post: Dariusz
Last Post: Marsikus
0 New oil tank
0 random rattle
0 Bike wobble question
0 top end rebuild
0 XLCH 900 1969 Build Thread
Last Post: XL1275
0 Clutch blow up
0 Stock vs. Modified
0 Membership $20? am I missing something here?
14 Buell back in business?
Last Post: AZbiker
0 Fyi
Last Post: AZbiker
6 Hello Folks
0 One for the dad joke collection
patc, Camera108 (67), pbudrovic (65), Rob Roy's Revenge (64), gene04 (63), guvnor (56), jrogers329 (50), ksoggs (45), dmurphy68 (43)
Old 1st August 2020
Mission1's Avatar
Mission1 Mission1 is offline
Sportster/Buell Year: 1988
Mission1 is just really niceMission1 is just really niceMission1 is just really niceMission1 is just really niceMission1 is just really niceMission1 is just really niceMission1 is just really niceMission1 is just really niceMission1 is just really niceMission1 is just really niceMission1 is just really nice
Default CV Carb hesitation
Because I am used to the Bendix and the Super E carbs, how do we adjust the CV carbs?! I’m getting major hesitation at start up!
Mark Cunningham 88’ 883/1200
Old 1st August 2020
There are many threads and posts on site with all the answers you’re liable to need. Also, peek into the C.V. Carb section in “Sportsterpedia” a most excellant resource. There’s a link in my signature.
Old 4th August 2020
Billy1200's Avatar
Billy1200 Billy1200 is offline
Sportster/Buell Model: XL1200 C
Other Motorcycle Model: Xvs650 dragstar
Billy1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to behold
As above , I'v had 2 sporties now both with carbs set up wrong .. It took me a while of asking and reading for it to click .. I'v found first thing is make sure the throttle blade is in its closed position and work from there ... Both my sporties were open too far so the mixture screw wasn't doing much but as soon as I had it running on idle circuit the difference in adjustments was much easier ( for that circuit ) .
You find the transfer ports " kick in" when they should
Not a tech answer but I'v found I'm a lot more confident knowing where to start and work up through the circuits ...
2002 XL 1200C
Old 4th August 2020
The Sportsterpedia has extensive information about tuning the CV40 Carb:
http://sportsterpedia.com/doku.php/techtalk:evo:carb02
You have to read it over carefully to understand all that is there and check everything properly from the tank all the way to the cylinders...
Old 8th August 2020
Mission1's Avatar
So now the CV carb’s over flow is pouring fuel upon turning the gas on?! Is the float sticking?!
Old 8th August 2020
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Float height setting is done at a angle.
Youtube videos show how a block of wood can be cut at angle to lean the carb against and check the float level.
Traveled to
stevehendo stevehendo is offline
Sportster/Buell Model: xlh1200C
Other Motorcycle Model: FLH, GY6, CT90
Other Motorcycle Year: 1980
stevehendo is an unknown quantity at this point
My bike was hesitating comming off idle often, until I stuck three washers under the carb needle. Same thing as ajustable needle with c lip and grooves. Piolot jet and mixture adgustment only did not work for me, though motor needed both. Everything is richer, but who knows if power is up from non stock pipes. I dought it, probbly not and maybe less. I wish I had some stock pipes to see.
That's not a solution for off-idle hesitation. If you follow the Sportsterpedia link above, carefully checking every aspect, and tuning as described, you should have a crisp throttle response - without the overly rich condition of 3-washers under the needle...
ReddTigger's Avatar
make sure that the idle is set a little high. once i went to 1050, i noticed that a lot of the hesitation went away.
but that is also part of making sure that the carb is set up right. follow the info. you'll be fine.
States I've Ridden in
71.3 hp 70.8 tq
