Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
Last Post: Hellbent_4
0 How Indian Makes 43% More Power than Harley-Davidson
0 Air Filter / Fuel Filter on a 2005 XL1200C
0 1981 Ironhead Dual disk question
0 What Carb
0 91 883 sporty died while riding, will not crank.
0 New sportster in HD Research Survey
0 Ironhead 1984 trouble shooting
0 Sportster Seat For Sale
Last Post: XM381
0 Fyi
Last Post: 1200CustomHD
0 80 sportster coil replacement ohms questions
Last Post: blk80bike
0 Points Assembly - Circuit Breaker Cam and Alignment Pins
Last Post: jbradley46
0 Help with oil pump drive gear
0 XLFORUM quit smoking thread
Last Post: XL1275
0 Replace sprocket
0 My 900: half-H, half-CH
Last Post: Parker 1000
0 stumble
0 FAF Sporties
Last Post: Smokin Sam
Last Post: bklyngeezer
0 1992 Sportster indicator module
0 Repainted my bike
Last Post: Samedward
0 My Cafe Build...2002 883R
0 Do people notice your bike?
Last Post: commando57
0 WTD: XL1200S SE Ignition module
Last Post: flak monkey
0 Removing transmission 1973 XLH
Last Post: Beary
0 Disassemble tranny HELP
irvingjr (72), 909XR (63), Ghost_FL (61), mark R (60), TWISTED (47), spade (45), Drivethis29 (40), dodgetrucken (35)
View Poll Results: What synthetic oil brand do you use in your cars or your bike. You choose more than 1
Amsoil 348 24.44%
Mobil1 545 38.27%
HD SYN3 295 20.72%
Royal purple 60 4.21%
Shell 17 1.19%
Castrol 84 5.90%
Penziol 14 0.98%
Other 224 15.73%
Multiple Choice Poll. Voters: 1424. You may not vote on this poll
  #441
Old 26th August 2019
ParrotHead's Avatar
Other Motorcycle Year: 1974
I used Amsoil on one Sporty engine and ran it over 150,000 miles before the top end had to even be opened up. Swapped the engine out for a very low mileage engine and ran it for over 150,000 miles using Mobil 1 Synthetic V-Twin oil. Put over 100,000 more on a rebuilt top end with the Mobil1. I have just about decided if you keep the oil changed and take care of the mechanical maintenance that it don't make a fiddler's damn what kind of oil you use, just so it is suitable for the application and listed for use in wet clutch systems. I am now using Lucas Full Synthetic Motorcycle Oil for wet clutch applications............. mainly just because it is easy to get.
I agree 100%
John Wayne - "The Shootist"
[URL="https://chrisridingadventures.wordpress.com/"]Check out my Blog[/URL] for my trip reports:
[URL="https://www.buzzsprout.com/129999/841095-episode-170-interview-with-chris-comly-of-chris-riding-adventures-blog"]Click here [/URL]to listen to my interview about my Sporty and riding on the Motorcycle Men Podcast
[URL="https://www.buzzsprout.com/129999/2188085-episode-221-interview-with-iron-butt-rally-veteran-chris-comly?fbclid=IwAR2AuBjIEvI8AoLtC7ZCZ4VC5Er_Guo8WfaRjh-15tRD9a5_rLYlp_jdJBg"]Click here [/URL]to listen to my interview about the Iron Butt Rally on the Motorcycle Men Podcast
[URL="https://horizon.bmwmoa.org/episode-93-chris-comly/"]
Click here[/URL] to listen to my interview on the Chasing the Horizon Podcast
[URL="http://sportsterpedia.com/doku.php/start"]Click here for the Sportsterpedia![/URL] for technical information & advice
Old 30th August 2019
juzyHD's Avatar
juzyHD juzyHD is offline
Master Bike Builder
Sportster/Buell Year: 1986
I don't care if my motor oil is for use in wet clutches. That gets oil made for gear boxes. What's good for one isn't what's best for the other.
Major motorcycle engines share the same oil in engine and gearbox. So if it is specified for both, I don't know why it shouldn't be good for both...
60Gunner's Avatar
60Gunner 60Gunner is offline
There's a difference between good for(read safe for) and best for. What's best for my motor is not safe for use in wet clutches.
Old 20th January 2020
duffy duffy is offline
Sportster/Buell Model: Anniversary 883 Hugger
Sportster/Buell Model #2: 03' Sportster 883 Hugger
duffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant future
Castrol 20-50 synthetic blend.
glbsportster's Avatar
glbsportster glbsportster is offline
Sportster/Buell Model: 1200 C
glbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond repute
For an engine to operate effectively and efficiently it requires many different qualities from it's motor oil and certainly one of the more important qualities is lubricity; since a clutch is using friction as it's main mechanical function.....probably lubricity is not high on it's list of requirements. Is a compromise between lubricity and friction worthwhile?
Old 7th February 2020
ParrotHead's Avatar
Ahh, but the same fluid lubricates the transmission and I'd think the gears and bearings would prefer lubrication over friction ...
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
And film strength/thickness... Clutch disc's cut thru the film, gears and bearings etc rely on it.
Old 12th February 2020
Rarely does a compromise of anything become an ideal situation....I have bought the $20 dollar container of gear oil sold by Harley for my Primary and gearbox......I will use Amsoil 15W-60 in the engine along with K & N chrome filter this time....next time a HD chrome filter will be on my bike (I have read in here it will make my bike go faster). I don't know this for a fact.....but I have been told Indian 15W-60 motorcycle oil is made by Amsoil to a formula (developed by Indian engineers) to help quiet the Indian Scout's engine. I have not been able to find out the Zinc, Phosphorus, Moly PPMs or if they have some other magical additives in the oil.....anybody in here know anything about the Indian motorcycle oil?
Graywolf Graywolf is offline
Speaking strictly about the Harley XL, I used Mobil 1 in the engine and used Ford Automatic Transmission Fluid in the primary and the gearbox. The XL has a Barnett Scorpion clutch and Barnett recommended the ATF for use with their clutch. I have worn out a few clutches, but never worn out a gearbox enough that it would need repair, other than the shift arms, , no matter what lubricant it had in it. I have put more miles on XL engines and transmissions in just a few years than most bikes get in their life time. My old 2001 XL now belongs to my son, along with the two parts bikes. I ride a 2019 Cam Am Spyder which has an integral lower end. The oil is shared with the engine and transmission. It is also a wet clutch. What is right for one engine may not be right or even possible for all motorcycle engines. The majority of motorcycles I have owned in my life had integral engine and gearboxes. I do realize this is an XL Forum, but many people also own more than one bike and have other brands of bikes with different oil requirements.
Graywolf
Toejam503's Avatar
Air-cooled Forever
Sportster/Buell Year #2: 1981
Everything I've read on Indian Oil 15W60, is that it has less Zinc and Phosphorus to preserve the catalytic converters. No one says how much is in it, tho. I think Harley Oil has been reformulated this way, too.
