Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Era Specific and Model Specific > XR Sportster Motorcycle Talk - XR750, XR1000, XR1200
XR Sportster Motorcycle Talk - XR750, XR1000, XR1200 For XR Sportsters: XR750, XR1000, XR1200
0 Dragging clutch
Last Post: Ark OB
0 Starter Relay?
Last Post: andy2175m4
0 Oil pressure switch
0 Q cams in 73 xlh ??
0 Carb ???
0 Video - FEED THE BEAST - Your Harley Will LOVE This Mod!
0 Deeded Electrical
0 It's Glamazon's Birthday!
0 need help with 68 XLH
flat track, flattrack, racing
Old 15th May 2008
duggram duggram is offline
Sportster/Buell Model: Buell 1125R
Sportster/Buell Model #2: XL1200R/XR1200 Storz
Other Motorcycle Model: Yamaha FJR
Other Motorcycle Year: 2008
duggram has disabled reputation
Default Flattrack Racing a Sportster
Does anyone know of sportsters being used for flattrack racing?
I'm talking about a stocker with mods, not an XR750. I want to make a street tracker out of my '07 1200R. My neighbor is a long time mechanic that would help me this winter making the bike convertible to dirt (lights off, front wheel brake off, ...). I was planning to use Storz parts.
883's were once an AMA pro class. Anyone have any experience from that era?
This could be a fun project. I used to TT and flattrack when I was a kid. There's no reason to get hurt, just playing around and at the least I'll have a nice street tracker next spring.
Any comments appreciated.
Doug
Old 15th May 2008
ReddTigger's Avatar
Doug
Check out the AMA site. you'll see that HD is very much still active in the FLAT TRACK racing.
Last year in the pro class, HD won the top 8 spots, 9 and 10 were suzuki and 11 and 12 were HD..
States I've Ridden in
71.3 hp 70.8 tq
Old 15th May 2008
ReddTigger's Avatar
You may also like this information..
Want to Race A Motorcycle?
Old 16th May 2008
Rags's Avatar
Rags Rags is offline
Sportster/Buell Model: XL 883R
Other Motorcycle Model: BMW R1150RS
Rags is an unknown quantity at this point
Doug
I have an '07. The rubber mounted rear motor mount is a problem on the newer frame. The rear motor mount is on 2 rubber donuts on the swing arm. On fast acceleration the motor torque creates lateral movement in the swingarm, then wallow (rear end steer).
The parts are #18 on the engine mounts page on the dealer Sporty parts book.
It may not make a difference on dirt, the slip may mediate the problem. However, sticky road tires w performance shocks does magnify the issue.
Old 20th May 2008
Ralphthe3rd's Avatar
Ralphthe3rd Ralphthe3rd is offline
Sportster/Buell Model: 883R
Sportster/Buell Model #2: Buell P3
Other Motorcycle Model: Ninja650R traded for 883R
Ralphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to behold
Arrow Flattrack Racing Sportsters...
Unfortunately the era of Racing Sportsters in Flattrack ENDED in 2005. There are still a few Supertrackers running 1200cc XL and Buell tuber engines, but their frames are purpose built race frames, and are closer to XR750 Race frames than they are to XL frames. BTW- the 883 series ended in '05 because of the introduction of the Rubbermount XL's in '04 which are totally UNSUITABLE for Flattrack racing.
FYI, the H-D 883 Sportster Performance Series was a support class run by the AMA in conjunction with the Grand National Championship series.
H-D 883 Series Champs from '93-'05 (2005 was Last Year for Series)
1993- Ricky Graham of Salinas Valley, CA (RIP)
1994- Scott Stump of Warminster, PA
1995- Mike Hacker of Carson, VA
1996- Eric Bostrom of El Segundo, CA
1997- Dave Camlin of Rock Island, IL
1998- Jess Roeder of Monroeville, OH
1999- Willie McCoy of Justin, TX
2000- Willie McCoy of Justin, TX
2001- Bryan Smith of Flint, MI
2002- Jared Mees of Honeybrook, PA (Great Kid)
2003- Scott Scherb of Decatur, TX
2004- Christopher Hart of San Jose, CA
2005- Scott Stump of Warminster, PA
Old 21st May 2008
Thanks for all the replies. Is there a way to replace the rubber donuts in an '07 that would make a more solid mount?
Is there anything else I could do to make the bike handle better? Longer shocks to improve fork angle?
Previous Bikes: '67 Bultaco Pursang, 305 Honda Scrambler, '72 Yamaha XS650, '74 Bultaco Frontera, '76 Bultaco Astro, '05 Dyna Glide
AMA District 36 #154D ('66 - '69)
Old 22nd May 2008
Arrow A Rubbermount will never be a Flattracker...
Sorry, but there is nothing you can do to make a Rubbermount suitable for flattrack, it would be way cheaper just to buy an old solidmount XL, then again... there is NO Sportster specific classes anymore. The only people racing a sportster based flattracker these days, would be in an Amateur Open class like the one for senior riders (age 40-up & 50-up), but most of those races are held on shorttracks and only on a 1/2mile(or mile) would a big fat sporty start working it's powerband.
Rubbermount XL's just aren't designed for Flattrack racing- plain and simple.
PS: FYI- even the old 883's were THE heaviest bikes to run in Flattrack in a few decades, but don't forget the late model rubbermounts are like 60lbs Heavier ! And most of that weight comes from the New frame and engine (aka Boat anchors).
Old 22nd May 2008
Rags's Avatar
As someone who is in the middle of finding a solution for the rubber donuts, my latest update:
Bought a rubber donut, my plan was to laser slice the center and replace with Dynel center donut to reduce squeeze. Brought it to a good machine shop that has a laser cutter.
Unfortunately, the laser can't cut that thick (3/8"). Mechanical precision slicing is only doable if rubber is frozen to -200/250 dgrees to take out flexibility. The new donut is larger than the old bagger donuts.
But HD has tried to mitigate the vibration with a stabilizer bar which is located top of the engine/frame ground. Its part #8 on the engine mounts page of the HD parts book. Tomorrow I'm going to look at the bushing (part # 6) of that stabilizer.
I leaning toward a fork damper as the final solution
That said, I agree; that the bike is not a good racing bike. I mean its cool, just can't handle fast.
BTW were the 883 racers using a HD frame? or custom.
Old 22nd May 2008
Arrow They were using a stock Frame per rules !
The 883 Roadracers AND Flattrackers were actually pretty close to stock specs in all areas, as the class was supposed to low cost and competitive.
I tuned an 883 Flattracker for a friend, and the rules didn't allow very much in the way of non-OEM parts swapping, so basically you just blueprinted eveything you couldn't change, and everything else that was allowed- you went with good stuff
BTW- almost all the 883 racers are now back on the roads in street legal trim.
~Ralph (gonna try not being so Feisty)
*Former- AMA N.E. District 2 Flattracker #15u '74-'84
Old 24th May 2008
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
Rags.....I have a Storz unit....it helps....but is NOT the final solution. I still believe like you that the flex in those bushings contribute to misalignment that exacerbates the wobble.
Bruce
Stuff: YES
