0 HSR idle mixture screw
0 Gear and brake linkage
Last Post: Andy56
Last Post: The Doctor71
0 oil to front rocker, no oil to rear?
Last Post: Hardtail28
Last Post: mrmom9r
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
0 78 Ironhead switchgear parts
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Q cams in 73 xlh ??
0 what are acceptable oils for primary ?
Last Post: Fivecats
black pearl (77), SDREDD (60), pig (58), BonRu (56), wandawells42 (52), cbass (48), HawkeyeTX, SxysCowboy (38)
Old 12th August 2019
Put a pan under the vent to catch the oil it will puke, this is normal after extended storage.
It will turn over slow because of the oil that has collected in the cases. It will crank slow also because of the accumulated oil.
Jump it off a car so you don't damage the battery from extended cranking. I use some spray carb cleaner to help it start.
It will stall and not want to idle untill it runs long enough to clear the oil from the cases. Do not add oil to the tank until it has run for a while as it will need the room for the oil that has collected in the motor.
GA_Ironhead GA_Ironhead is online now
GA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond repute
Make sure that the fuel is fresh.
On the plus side, Americans are learning the Greek alphabet.
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Year: 79
Will do thank you
mickey t's Avatar
Yes I went n got fresh premium to put in there...put a new tank on there so its got nothing but fresh gas
Old 13th August 2019
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Now time to go buy beers. Round up some bodies. Find a slope.
Squirt gas in da carb throat. Old mustard bottle works for me.
Roll that sucka down hill making sure petcock is on, jump start with bodies, and see what happens next.
I'd worry about the kicker later.
Traveled to
mickey t's Avatar
RAIDER0372 RAIDER0372 is offline
Sportster/Buell Model: NIGHTSTER
RAIDER0372 is an unknown quantity at this point
RIDE HARD.
GOD SPEED.
mickey t's Avatar
while it was sitting for a couple of months, did you keep the battery on a tender or get a new battery? if it's the old battery it could just be dead or not enough juice to light it off.
Hey brother...I believe it was you who steered me in the direction if tje Mikuni vm38...did you say that the idle screw n mix were opposite of S&S?
doodah man's Avatar
The mix screw is backwards from most other carbs, it controls air instead of fuel. So turning it in, closes off air making it richer, and out for leaner/more air.
mickey t's Avatar
Ok thank you
