Last Post: Fivecats
0 Q cams in 73 xlh ??
0 HSR idle mixture screw
0 Oil pressure switch
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
0 Gear and brake linkage
Last Post: The Doctor71
0 oil to front rocker, no oil to rear?
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
0 78 Ironhead switchgear parts
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
  #51
Old 5th August 2021
I do envy you guys who can still kick 3 and 4 times.
And don't forget, if you make it look easy to the bystanders they won't think it's a hot rod engine. (Which it is).
No No No Gene.
You make it look easy, and then you can be entertained, when someone who wants to ride it has to start it!
Old 5th August 2021
Ferrous Head's Avatar
Ferrous Head Ferrous Head is online now
Blind Owl
Sportster/Buell Year #2: 1966
No No No Gene.
You have to be careful there.
The local "bad guy" (bully type - years older than me) once bet my brother he could kick start my brother's Sportster. (A feat I had only seen performed once in my life)
Short story, he broke his ankle on about the 5th kick. On crutches for 2 months.
I made the mistake of laughing at him.
Had to keep well away from him for the next couple of years. And he only lived a block away from me.
Old 6th August 2021
I kick started one by hand! I have witnesses...
Old 6th August 2021
Blind Owl
We need to see the video Rick.
Not that we doubt you, just that we want to see the girls who were watching you at this time.
Old 6th August 2021
Sportster/Buell Year: 1969
I traded my 75 XLCH in on a 76 FX because a friend had an FL he would start frequently by hand. My XLCH was a leg snapper. I later found out his FL was 7 to 1 compression. I put 4.5 wheels in the FX with 10 to 1 still easier to kick than the XLCH. My current 69 XLH has a kicker I use infrequently since I have had to weld the sprocket cover.
Old 6th August 2021
Sportster/Buell Year #2: '03
that's a fairly common stroker motor issue.i've had to do that with 2 different sprocket covers.once you get some good tig rod in there they seldom break again..unless the clearance in the kicker shaft bushing is minimal.
Old 7th August 2021
I use the kicker primarily to adjust lifters now if I don't need to put the bike on the lift for anything else. I did weld up the cracked sprocket cover with a heavy bead. It should hold up if needed.
Old 15th August 2021
rykk69 rykk69 is offline
Sportster/Buell Year: 69
rykk69 is an unknown quantity at this point
So, my timing plug blew out - it was stripped, but had been hanging in with red loctite. Tapped it out to 11/16 very carefully (stuffed piece of pantyhose in hole and greased up the tap, removing a few times to clean out chips) and installed over sized plug.
Again was a bitch to get started. I will experiment with fewer prime kicks and no throttle. I have also been wondering about intake leaks- I did pull the manifold as part of troubleshooting- alignment and o-rings seem fine. I did notice yesterday that there are some cracks in the rubber connector from manifold to carb but they don’t seem to be deep. Is there a way to test for intake leaks?
Now that there is a couple hundred miles on the build I am also going to recheck pushrod adjustment.
propane torch.without lighting it aim the gas at the rubber piece with the motor running.if you have a leak the idle speed will increase.
Old 16th August 2021
Spray cleaner works also, but just dribble it
