Last Post: andy2175m4
0 Carb ???
0 2021 Iron Butt Rally
0 Mainshaft Oil Seal Leak
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
0 HSR idle mixture screw
0 Q cams in 73 xlh ??
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
gary59 gary59 is offline
Sportster/Buell Model: 883
gary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enough
Default Intake Seals
Should I put grease on new intake seals when installing?
sungod's Avatar
sungod sungod is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 73
Default intake seals
I install them dry.
John Harper's Avatar
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
Red high temperature grease!
John
I used silicone grease on mine. It won't attack the rubber.
LLOYD883's Avatar
LLOYD883 LLOYD883 is offline
Sportster/Buell Model: xl883c
LLOYD883 has a reputation beyond reputeLLOYD883 has a reputation beyond reputeLLOYD883 has a reputation beyond reputeLLOYD883 has a reputation beyond reputeLLOYD883 has a reputation beyond reputeLLOYD883 has a reputation beyond reputeLLOYD883 has a reputation beyond reputeLLOYD883 has a reputation beyond reputeLLOYD883 has a reputation beyond reputeLLOYD883 has a reputation beyond reputeLLOYD883 has a reputation beyond repute
I followed the factory manual when installing new seals after head porting.
Apply a liberal amount of engine oil to valve stem before installing the valve.
Place a protective sleeve over the keeper groove and coat the sleeve with oil.
The sleeve is necessary to protect the new seal from being damaged by the
sharp edges of the keeper groove.
2005 883XLC - 42 slow jet, 2 1/2 turns out - N65A needle shimmed 0.030" with stock 170 main jet - 07 1200 W cams - mildly ported stock heads - Arlen Ness Big Sucker air cleaner with HD round nostalgia cover - Khrome Werks 3" tapered slip-ons - SE 1200 ignition module - microTach - Mustang "solo tripper" seat - 12 1/2" Progressive 412 chrome rear shocks.
Andy56 Andy56 is offline
Didn't you ask this question on the "other" forum?
Sportster/Buell Model: XL 1200 softail frame&NOS
Randy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant future
I would not! Grease can cause the seals to squeeze out of place.
I have tried it with red rubber grease and they failed right away.
Install them dry.
Install them dry.
I've changed quite a few manifold seals using red high temp grease. Never had a problem with them failing. Never.
John
Sportster/Buell Year #2: '03
check your f.s.m. lubricate with dish soap detergent or tire lube.from my '03 f.s.m.
Would you show that bit in FSM? Because there's no mention about greasing the intake seals in any of my factory manuals.
