0 It's Glamazon's Birthday!
0 First start question
Last Post: Jaime1840
0 Q cams in 73 xlh ??
Last Post: 73HEAD
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 HSR idle mixture screw
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
  #31
Sportster/Buell Year: 1969
There IS a Kitty Hawk...
But if in 1903 they had wanted to fly like a bird we might not have our beloved V Twins. Who knows if Indian or any of the others would have evolved.
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Thank Heavens they didn't want to fly like a bird but instead, .... walk like a Turkey.
Blind Owl
I shouldn't be so down on HD.
I guess it's easy with hindsight. And knowing how large companies work (or mostly don't) I should just appreciate they have lasted so long.
It will be a sad hing to see them go.
mrmom9r's Avatar
mrmom9r mrmom9r is offline
mrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond repute
Originally Posted by thefrenchowl View Post
sungod,
i don't know in the usa, but here in gb, you can buy quite a handful of circlips for the cost of one ptfe button...
Hence why most accountants will prefer the circlips!!!!!!!!!!!!!!!!!!
Patrick
bingo , bingo , bingo .
mrmom9r's Avatar
Willy G. Father of the Boat Tail Sportster.
How could I have forgotten his wrist pin expertise?
Wrist pin buttons? He might know something about conch buttons or leather streamers.
sungod's Avatar
sungod sungod is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 73
Default teflon vs circlips
Off topic:I once had a boatail fender bird bath but the birds would not use it!
Too funny!
rocketnorton's Avatar
Other Motorcycle Year: 80+
rocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud of
Originally Posted by RicThompson View Post
sungod you don't know how grateful I am that Willie G and his engineers didn't build aircraft. Just saying.
qtla
pete
kitabel kitabel is offline
Sportster/Buell Year: 1989
I lightly radius the buttons to fit better with the piston profile
This^^^
If you don't, the circumference (corners) will wear off first and make the buttons shorter.
If you even think the clip was twisted, expanded, etc. throw it away.
billeuze's Avatar
billeuze billeuze is online now
Sportster/Buell Year: 80s
Other Motorcycle Year: 1983
billeuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond repute
Thanks everyone. Sounds like overwelming recomendation to use buttons. So that's what I've decided to do. I trimmed mine down a bit to create the recommended .06" float. Strange that S&S would sell them this way with just .01" float. I can't be certain S&S supplied these buttons with the pistons because I bought the boxes of engine parts years ago from someone on this forum, Included in the boxes were pistons, rings, wrist pins and buttons. The Pistons are S&S branded, the rings are too. And I've seen on ebay piston kits from S&S that include wrist pins, the same pistons, same rings in the same packaging and same buttons in the same little brown paper baggie. So odds are this was originally a kit from S&S.
