Last Post: Ron Bizzle
Last Post: Reverend G
Last Post: mac93
0 Starter Relay?
Last Post: Magneto Sportster
0 First start question
5 Rethinking 1250 Build
Last Post: Desertfox
Last Post: Fivecats
Last Post: lehel
0 Sportster R.I.P.
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: LLOYD883
0 help with stuck engine
Last Post: speedyrette
Last Post: 99-883-c
0 1982 rubber oil hoses
Last Post: Gravitas
0 33.4mm fork bushings
Last Post: Staffords
Pappa G Pappa G is offline
Other Motorcycle Model: softail deluxe
Other Motorcycle Year: 2007
Pappa G is an unknown quantity at this point
Default changing from stock gas tank
got a new gas tank for my 1995 1200 sportster, the old tank had the small vapor tube that attached to the frame tube stand pipe between the battery tray and the oil tank. the new tank has a small fitting i assume for the same vapor line, if i use a vented gas cap can i eliminate the vapor tube.
Edster's Avatar
Edster Edster is offline
Edster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant future
I think the tube is more for overflow than venting. I could be wrong. I put a 96 tank on my 03 and both have that feeling/tube. But think you'll be fine with just a vented cap. Just be aware of how much you fill the tank.
Sent from my LM-G900TM using Tapatalk
gary59 gary59 is offline
Sportster/Buell Model: 883
gary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enough
That fitting under the tank vents it into a canister for emissions. You can get you a vented cap at lowbrow customs if needed and not use that fitting.
Here's the Sportsterpedia section regarding the Tank Vent Tube:
http://sportsterpedia.com/doku.php/t...e_tank_venting
I'm quite sure that all the tanks from 1992-2003 use a vented fuel cap. It's likely that 2004-2006 also use one.
So, the original design (for those years) has BOTH the vented fuel cap & the tank vent tube.
I expect the cap only lets AIR IN (probably) while the tank vent tube, connected to the vapor valve, ONLY LETS AIR OUT.
For Sportster Tech Info:
