0 Starter Relay?
Last Post: speedyrette
Last Post: 99-883-c
0 1982 rubber oil hoses
Last Post: Gravitas
0 33.4mm fork bushings
Last Post: Staffords
0 help with stuck engine
Last Post: motorfish
0 Oil leaking :-(
0 HELP!!! 2019 HD Iron 883
Last Post: Mr Dream Merchant
Last Post: iBloke
0 Dunlop K81 Roadmasters? Anyone?
Last Post: ZTatZAU
0 Exhaust question
0 Electrical problems.
Last Post: Gravitas
Papatony, chedd (76), Nevar (71), nrbase (69), Smokin-Smitty (64), kbfarkas (62), Irondreads (52), Tim97509 (51), CCM0021 (50), wandrur, bikerusn5 (38)
Old 12th July 2012
DGranite's Avatar
DGranite DGranite is offline
Sportster/Buell Year: 1979
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1977
Other Motorcycle Model: Sturgis FXB
Other Motorcycle Year: 1981
DGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the rough
Default Tappet Roller kits questions
Back with more questions.
I have some bad tappets.
I dont have much money right now.
I want to ride my bike.
My question is has anyone used any of the replacement Tappet roller kits?
http://www.jpcycles.com/product/4300368
http://www.jpcycles.com/product/431-458
and what EXACTLY is a radius crimping anvil? i know only the "JIMS" ones, which cost twice as much, say you need one,
But Im guessing youd need one either way.
Could I use a 20 ton press? Have lots of different Metal rods, at least one with a rounded end (about like a half of a 1/2" ball bearing) etc to use with it.
So anyone done it?
Do you drill the old ones out? Grind the ends off and press out?
Any help would be appreciated to see if this is doable for me.
$55 versus $150-200 could mean an extra 2-3 weeks right now.
and summer is half over here.....
Old 12th July 2012
MN Mailman's Avatar
MN Mailman MN Mailman is offline
Sportster/Buell Model: AMF XLS Roadster
Sportster/Buell Year: 1981
MN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of light
So anyone done it?
Do not get the first link, imported ones. 10-1 they are junk. You get what you pay for, and Jims are quality products, and quality products are the only kind that should go in your bike.
I'll leave the other questions to others.
Question Authority
Old 12th July 2012
Mike650 Mike650 is offline
Sportster/Buell Model: Ironhead Sportster
Mike650 is an unknown quantity at this point
i would just buy new ones, pop em in and ride. less headache. dont have to worry about proper installation of those pins. sure its a little more expensive, but could be cheaper in the long run if one of those pins decided it didnt want to install correctly and falls out into your motor and tears it up. going the cheaper route isnt always the cheaper route.
Old 12th July 2012
DGranite's Avatar
I cant believe I missed that lol.
Just got armature, via my local dealer,From Harley Davidson milwaukee Wisconsin....marked Just above the address....Made in Taiwan.
So much for made in America.
Old 12th July 2012
Sportster/Buell Year #2: '03
if you dont have the proper equipent or,experience,i,would not attempt this.if you think your tappets are bad now.attempting this could put you into more serious,trouble. buy quality replacement tappets,and reinstall.
Old 12th July 2012
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
Buy the roller kits from the dealer. They're still available. P/N 18534-29A. They don't require any "special" tools to replace. The OEM roller axles are NOT a heavy press fit in the lifter body. The axles aren't even that "hard" and the end will deform quite easily. H-D riders have been replacing them on the workbench, the side of the road, in motel rooms, etc., for over 80yrs.. If there was a problem with them I'm pretty sure the MoCo would have quit selling them a lonnnnnnnnnnnnnnnnng time ago.
And yeah, Jim's lifter axles are a HEAVY press fit. In fact, it's such a heavy press fit that even Jim's won't replace the rollers in their lifters. If it wears out, you get to buy new lifters, regardless of the mileage on them, because Jim's won't warranty them for premature wear.
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb soxxet genuine Aftermarket rear fender generic countershaft sproxxet Radio Shaxx 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
Old 12th July 2012
DGranite's Avatar
Thanks for the replies everyone.
MN Mailman, good eye, your right, I Dont want imported ones if I can avoid it. But right now the JIMS ones are out of budget and I dont have the tool required (though I think a friend may, gotta catch up with him)
Mike, I would Love to buy some new ones and pop them in.....I just dont have the money for that right now and Id like to ride before September. I have all winter for new Tappets. Good ones. Or By September I should haver some extra money for new good tappets I may end up having to go this route..
Brucstoudt, I Dont have the exact done this job before experience, I dont know exactly what tools are needed so I dont know If I have oor have access to them, And as above...would love to put new quality tappets in, but that is probably late August or September away money wise.
Rivethog, from your post you seem to think it is a doable thing..roadside is my specialty I rebuilt the rear driveshaft in my 4x4 Bronco in the driveway of the machine shop Yesterday with a pair of longnose pliers, a Screwdriver, 12mm wrench and a hammer after driving 35 miles in front wheel drive to get there.
If as your post suggests you have done this, could you tell me what tools Ill need? any thing in particular to watch for? How you did it?
Ive found some Sifton rollers, are these a better choice?
I will call my dealer in the morning to see if they have or can get me some.
I would love to hear more.
Thank you all once more for the help and ideas.
Keep them coming
Old 12th July 2012
Ponderosa's Avatar
Ponderosa Ponderosa is offline
Ponderosa is a jewel in the roughPonderosa is a jewel in the roughPonderosa is a jewel in the roughPonderosa is a jewel in the roughPonderosa is a jewel in the roughPonderosa is a jewel in the roughPonderosa is a jewel in the roughPonderosa is a jewel in the roughPonderosa is a jewel in the roughPonderosa is a jewel in the roughPonderosa is a jewel in the rough
Default Tell ya what...
I did it years ago, tried it again and failed... Put the old roller in the vise, just the roller.. Drill out both sides of the pin, do not hit with a punch, this can and will split the plunger! Make sure you have the pin loose then just push the old pin and roller out by hand.. Once you have the new pin and roller in I just used a large center punch to set both sides, laying the opposing side flat on a solid surface, then moved to a press with a punch attachment and finished it off.. Be aware, I screwed mine up this time, then got pissed and bought a set of tappets and housings.. Murphy has a way of catching up, and kicking your ass..
Old 12th July 2012
tracbike's Avatar
tracbike tracbike is offline
Sportster/Buell Model #2: Sportster XLH
Other Motorcycle Model: Trac Dynamics / Razor,
tracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the rough
So anyone done it?
I saw a nice set on ebay today I think out of a 80/ there are multple sets enter ironhead sportster tappets in search.... these look the best you can see the whole tappet
http://www.ebay.com/itm/1980-Sportst...984362&vxp=mtr
Old 12th July 2012
DGranite's Avatar
Ponderosa,
Hate to bring up bad memeories...but what did you do wrong this time?
I figure a mistake is a lesson, and I can learn from yours as well as my own...what should I NOT do? Were you using a hand drill? or did you have the vise in a drill press?
Cause I dont need ANOTHER visit from Mr Murphy...he's been here the past 2 weeks! lol
Thanks.
