0 Gear and brake linkage
Last Post: 93trident
0 Oil pressure switch
Last Post: Andy56
0 why you can't be seen
Last Post: Andy56
0 What oil temp do you run
Last Post: Andy56
Last Post: Fivecats
0 need help with 68 XLH
Last Post: mrmom9r
0 HSR idle mixture screw
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
  #31
Old 27th July 2012
Sportster/Buell Year #2: '03
i'm,glad you were happy with the,diagnosis. check your,reputation.
Old 28th July 2012
DGranite's Avatar
DGranite DGranite is offline
Sportster/Buell Year: 1979
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1977
Other Motorcycle Model: Sturgis FXB
Other Motorcycle Year: 1981
DGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the roughDGranite is a jewel in the rough
Well that was certainly unexpected!...and I thank you.
Old 3 Weeks Ago
alfajuj alfajuj is offline
Sportster/Buell Year: 1988
alfajuj is a glorious beacon of lightalfajuj is a glorious beacon of lightalfajuj is a glorious beacon of lightalfajuj is a glorious beacon of lightalfajuj is a glorious beacon of lightalfajuj is a glorious beacon of lightalfajuj is a glorious beacon of lightalfajuj is a glorious beacon of lightalfajuj is a glorious beacon of lightalfajuj is a glorious beacon of lightalfajuj is a glorious beacon of light
For posterity, I'd just like to add that you don't ever need to file the rivets down. You should keep peening them with a flat punch until they're completely flush with the ear. You also need to check the side clearance of the roller and keep peening until the clearance stops decreasing (Usually about 10 or 12 thou, depending). The side clearance should end up being the same as the difference in width between the race and the roller. The goal is to make sure that the ears are tightly and completely trapping the race, so that it won't have any chance to spin. If the race is allowed to spin, the rivet, which is just soft metal, will quickly wear away and the roller will fail.
Old 3 Weeks Ago
bill smith bill smith is offline
Sportster/Buell Year: 1971
bill smith has disabled reputation
Absolute positive advice right there, and as another sidenote where do the filings happen to go? think they might migrate to the needles??
