Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > SuperBrace
0 Carb ???
Last Post: andy2175m4
0 2021 Iron Butt Rally
0 Mainshaft Oil Seal Leak
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Old 14th May 2013
2011-XL1200C's Avatar
2011-XL1200C 2011-XL1200C is offline
Sportster/Buell Model: XLl1200C
2011-XL1200C is an unknown quantity at this point
Default Superbrace for the new 48s and customs ?
Has anyone tried a Superbrace on the wider forks and 130/90 16 front tire of XLC 2011 and 48s.
1250Hammer, Crush,.600, Sledge air, Rush 1.75", WB-PV-1, Superbrace, Intimidators,
Old 24th December 2014
Sportster/Buell Year #2: 2008
Was wondering about this too.
Rog48's Avatar
Rog48 Rog48 is offline
Sportster/Buell Model: 48
Other Motorcycle Model: Kawasaki KZ650
Other Motorcycle Year: 1977
Rog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant future
Not needed on the 48. It has a very substantial chunk of metal for a brace already. Its a handy place to mount your fender too
2011 XL1200X - 1977 KZ650 - 1982 KZ1100 - 2006 TW200 - 2009 TW200
Old 25th December 2014
Default Needs Brakes
On the contrary my friend.
The 48 needs a second brake caliper to stop and the fork tubes will differ, thereby needing a brace.
Might have to go to another width triple tree in order to get the complete setup needed but that is getting too complicated already, might just slide the turbo on to the Roadster with two front brakes already.
Old 27th December 2014
Rog48's Avatar
Your reasoning makes no sense.
A second brake makes no sense?
The fork tubes that have lugs to hang a brake caliper off of do not have the neat fork brace the stock 48 has.
So a fork brace is likely needed....
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
The 48 has an integral fork brace that bolts to the lower fork legs. The Custom doesn't, so a regular fork brace could be installed on it. Of course, if you changed the lower legs on a 48 to fit dual discs, then the factory brace wouldn't work any more.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
If you change the lower legs on a 48 to fit dual disks, it's no longer a 48 fork.
That doesn't change the fact that the 48 fork already has a fork brace, and doesn't need (and can't accommodate) another.
Folkie
South East England Riders
Default Keeping it Simple?
Wanted, a set of fork braces the width of 39mm fork tubes in the 48 triple trees.
With all the different parts on my Sportster it is hard to recognize it as a 48.
Just made it mine and that is just mighty fine.
Old 28th December 2014
Rog48's Avatar
Not what I said. Your post makes no sense. The question was about a fork brace for a 48, the 48 already has a beefy one so does not need one. Your response was if you swap out pretty much the whole front end then you need one...................related to the question posed.....your response makes no sense.
