0 What oil temp do you run
Last Post: fafcpa
0 Gear and brake linkage
Last Post: 93trident
0 Oil pressure switch
Last Post: Andy56
0 why you can't be seen
Last Post: Andy56
Last Post: Fivecats
0 need help with 68 XLH
Last Post: mrmom9r
0 HSR idle mixture screw
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
  #5341
Old 4 Weeks Ago
Sportster/Buell Year #2: '03
^^^looks like a belt final drive on that?
Old 4 Weeks Ago
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
It is.
I spent a hour on it this eve, ran the valves, fixed a petcock leak, adj clutch and put a battery in it. Looked in the spark plug holes and confirmed new pistons. Put the plugs back in, put some gas and hit the button. Purred like a kitten.
Too bad it has those goofy bars and that silly tank. At least it distracts me from the pipes.
I’m not even letting this one in the garage, it has to go…soon.
Old 4 Weeks Ago
Brad's Avatar
Brad Brad is offline
Sportster/Buell Model #2: 883C/883R/1200C-all sold
Sportster/Buell Year #2: many
Originally Posted by Iron Mike View Post
It is.
For how much????
1995 XL 883 - Phoenix, AZ
Old 4 Weeks Ago
$1000. You must be seeing the same bikes as me if your in the area.
Old 3 Weeks Ago
https://phoenix.craigslist.org/wvl/m...386021065.html
Old 3 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
He's been trying o sell it for a while now.
While it's interesting to look at I would have serious reservations about it being a successful race bike.
My biggest concern would be the strength of the frame in the neck area. Sidecars aren't solo's and the strain on the neck will twist it unless properly designed.
In Australia we have a class that suits Ironheads perfectly. Period 3. But this is not a Period 3 and would have to race against Period 4 bikes. That includes Honda 4's. You need 120 hp at a minimum to compete successfully.
I looked at racing mine in the US. But the rules here would make it impossible for me. I can't make hood HP and run on a long track while running gas.
Old 3 Weeks Ago
braze and welded are not the same thing where i come from. AWS certified all positions unlimited thickness.
Old 3 Weeks Ago
^^simulpost!
Old 3 Weeks Ago
Blind Owl
Having another look and I see another problem or two.
The key to sidecar handling is getting as much weight on the front wheel as you can. The engine is too far back from the contact patch on the front tire.
Also there is no seat position. This is what we call a "kneeler" as you kneel on the bike rather than sit on it. That's a knee cup just underneath what would be the seat.
But if your forced to kneel for every single minute you are on the bike it will take too big a toll on your legs. The bike needs to be designed so that you "lay" on it more than kneel.
Old 3 Weeks Ago
Blind Owl
Braze welding is more commonly known as bronze welding. It is a welssing process as the metals are fused. It's not brazing as such.
used on Manx Norton frames and the like. uses less heat and therefor better than welded joints.
