0 1975 Sportster
Last Post: alsfarms
Last Post: Porkchop9
Last Post: diver
Last Post: jibber
Last Post: Gulf Coaster
Last Post: paulc
0 Gear and brake linkage
Last Post: 93trident
0 1965 XLRTT article
0 Starter Relay?
Last Post: Akdawg
Last Post: mac93
0 Q cams in 73 xlh ??
Last Post: 73HEAD
0 Dragging clutch
0 Oil pressure switch
Old 11th August 2019
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Year: 79
Default First startup
Hey all I just buttoned everything up on my 71 xlch...kicking it over w nothing but a xouple pops...I also had oil spit out my vent tube..is that just extra oil that's in there?I would imagine it would take a bit to kick over it ran when I bought it but just had it sit for a couple months while I did some work on it...nothing major in the motor or trans...new tank fender stuff like that..any tips on what to look for while trying to kick her over again ?
IronMick's Avatar
IronMick IronMick is online now
Rider Of The Iron Steed
Originally Posted by mickey t View Post
...I also had oil spit out my vent tube..is that just extra oil that's in there?...
Yes, most likely
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Old 12th August 2019
doodah man's Avatar
while it was sitting for a couple of months, did you keep the battery on a tender or get a new battery? if it's the old battery it could just be dead or not enough juice to light it off.
mickey t's Avatar
Well it wasn't on a constant tender...what I did was charge it to full charge..remoced it then charged to full charge again before I tried to kick it....if it shows full charge could it still ne weak to kick it over?
GA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond repute
Wet sumped... All part of their charm.
http://xlforum.net/forums/showpost.p...8&postcount=40
On the plus side, Americans are learning the Greek alphabet.
IronMick's Avatar
To be good, a battery must satisfy all three conditions...
  • it must take a charge
  • it must hold the charge over time
  • it must hold the charge under load
So
  1. give it a full charge,
  2. disconnect the charger and let it sit for 24 hours,
  3. attach a voltmeter, watch the voltmeter while cranking the engine with the starter button. The reading should not drop below 10 or 11 [people have different opinions here] volts.
If you have a kick only go to Princess Auto or Harbor Freight and buy a battery load tester. They are not overly expensive. Every IronHead owner should have one. Saves those stupid trips out to get it load tested.
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Every Ironhead owner with a battery.
mickey t's Avatar
So
Now that you explained it like that I should probably go buy a new battery....I will do the test like you explained though
mickey t's Avatar
I do not I e that after I do a full charge n I wait a couple days I hook up the charger again n it shows low w the red light...then after a bit it'll turn green for the full charge
mickey t's Avatar
Good point
