0 help with stuck engine
0 First start question
Last Post: mac93
0 Starter Relay?
5 Rethinking 1250 Build
Last Post: Desertfox
Last Post: Fivecats
Last Post: lehel
0 Sportster R.I.P.
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: speedyrette
Last Post: 99-883-c
0 1982 rubber oil hoses
Last Post: Gravitas
0 33.4mm fork bushings
Last Post: Staffords
1275, big bore kit, custom build, custom oil tank, lithium ion battery
  #1301
Old 26th July 2021
Hippysmack's Avatar
Hippysmack Hippysmack is online now
See how much room silliness takes up?
Now imagine how big this picture would be by listing all the noises on a Sportster....
This page about noises in the Sportsterpedia is already huge but still scantily clad.
http://sportsterpedia.com/doku.php/t...k:ref:genmsr05
Old 27th July 2021
BestCoastXL's Avatar
BestCoastXL BestCoastXL is offline
Disassembly Specialist
Sportster/Buell Model: XL883L
Sportster/Buell Model #2: XL883L/1275
BestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond repute
Search: "How to Break the Internet"
Old 27th July 2021
I upgraded my shoe and best I can remember, the torque on the nut was lower than original.
So I'm wondering if I should replace the nut and pull it down to original torque.
But I can't see how 1 bolt thru the center will keep it still.
Obviously it is the same design as others that don't have that noise so it may just me.
What did you upgrade it to? Different part number than the blue Drag Specialties offering?
Old 27th July 2021
H.D. Brought out an upgraded part, the steel shoe supporting the nylon wear bar was thicker gage metal. Of course I could be wrong.
I.B.A.#26543,
Old 27th July 2021
Hippysmack's Avatar
Because at the time I was doing my conversion, I was given the information about it, looked into it and found it beefier.
So I figured, why not.
My old once did have a good bit of wear.
If you think about, it's just (nylon or some other type) plastic.
That metal chain will always win that battle.
Old 1st August 2021
So now that parts have shown up I can carry on with re-Assembly to some extent.
I’ll also be incorporating some 3 pin waterproof connectors that have a 3 amp capacity; more than enough for what I’m working with.
I’ve also had the primary gasket, base and head gaskets, new lifters and copper exhaust gaskets show up so i’ll Make some progress with that while the seat is getting finished.
Old 1st August 2021
Hippysmack's Avatar
I use dialectic grease for waterproofing connectors.
(had a shutdown in pouring rain on the highway and have used dialectic grease ever since)
Old 1st August 2021
I agree completely if the connector isn’t designed to seal out water. I do use a dab around starter terminals that are exposed to oxidation, corrosion moisture and contamination. Every substance on earth that I can recall has an atomic level of charge so I like to give it all a fighting chance.
Old 1st August 2021
I’ll be adding in a brake switch up front this time around seeing as how I have the harness exposed.
Not really a big deal to add it in; just switch wire and a ground.
What I want to know is if I should siphon out the brake reservoir so that I minimize the mess while swapping the banjo bolts?
Does that one answer itself?
Old 2nd August 2021
Hippysmack's Avatar
2005 uses DOT 5 so it's just a mess (no paint stripping involved).
But yes, it does.
