Last Post: 4cam
0 help with stuck engine
0 First start question
Last Post: mac93
0 Starter Relay?
5 Rethinking 1250 Build
Last Post: Desertfox
Last Post: Fivecats
Last Post: lehel
0 Sportster R.I.P.
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: speedyrette
Last Post: 99-883-c
0 1982 rubber oil hoses
Last Post: Gravitas
1275, big bore kit, custom build, custom oil tank, lithium ion battery
  #1381
Old 24th August 2021
Originally Posted by BestCoastXL View Post
Today I received the Oil seal for the Primary Cover.
<SNIP>
Then, using a 13 mm deep socket(for something to grab on to) I gently wiggled the socket on top of the seal until it seated up against the bushing.
A quick visual check shows that the seal is now squarely up against the bushing and ready for service.
I hate to mention this because your install may work out just fine, but:
http://sportsterpedia.com/doku.php/t...ifter_assembly
NOTE: There is a TSB (M-1350) related to the 'NEW' Shifter Shaft Seal P/N 11000101 being installed with Special Tool HD-51337. The new seal has a 'garter spring' to help seal the shifter shaft from leaks. In this TSB, the following caution is made: If the tool is not used, install seal to a depth of 0.125-0.135 inches. DO NOT bottom the seal in the bore. Bottoming the seal will damage it and prevent it from sealing properly. (While this bulletin refers to Big Twins with 6-spd transmissions, this shifter shaft seal is used on other models, including the Sportsters.)
For Sportster Tech Info:
HawkeyeTX's Avatar
HawkeyeTX HawkeyeTX is offline
Sportster/Buell Model: 1200XLC
Sportster/Buell Model #2: 883XL
Sportster/Buell Year #2: 1986
HawkeyeTX has a reputation beyond reputeHawkeyeTX has a reputation beyond reputeHawkeyeTX has a reputation beyond reputeHawkeyeTX has a reputation beyond reputeHawkeyeTX has a reputation beyond reputeHawkeyeTX has a reputation beyond reputeHawkeyeTX has a reputation beyond reputeHawkeyeTX has a reputation beyond reputeHawkeyeTX has a reputation beyond reputeHawkeyeTX has a reputation beyond reputeHawkeyeTX has a reputation beyond repute
https://www.georges-garage.com/produ...l-installer-2/
I used something similar to the tool listed in this link when installing a new seal on my '86 Sportster. Keeps the seal from bottoming out in the transmission case and sets it to the correct depth.
Black Beauty - 2007 XL1200 Custom
Too many updates to list. Let's say I've spent more in upgrades than I paid.... but how many times over is your guess.
My 1275 Hammer Performance upgrade http://xlforum.net/forums/showthread.php?t=2078737 IT WAS DELETED BECAUSE OF HAMMER'S SHODDY QUALITY CONTROL
BestCoastXL's Avatar
BestCoastXL BestCoastXL is offline
Disassembly Specialist
Sportster/Buell Model: XL883L
Sportster/Buell Model #2: XL883L/1275
BestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond repute
Hmm, now is a good a time as any to check my understanding.
How does putting the seal up against the bushing with no apparent difference in mating around the shaft cause a degrade in performance?
I would have thought that fluid pressure being what it is, if fluid got between the seal and the bushing in the cover then even though there’s a vent, fluid might work against the seal and cause a leak in that manner.
I might be way off...but does anyone have a picture of the tool and can describe the operation of it?
Edit: nvm.
http://sportsterpedia.com/lib/exe/fe...in:tsb1350.pdf
This too I can see gets in between the garter spring and the outer wall of the seal and sets it to the right depth.
If I measure with a caliper I can tell if I’m good to go.
The more important question now is if there’s the oil seal AND the rubber spacer that goes between the seal and the shifter lever/pawl then how does the seal being bottomed into the cover end up being affected if the spacer seals that seal off anyways?
HawkeyeTX's Avatar
See the link for a picture. It slides over the shifter shaft and bottoms out on the transmission cover. Nothing to it really.
This would not be the first time that Harley has been wrong on a measurement.
Belt tension anyone?
See my edit.
HawkeyeTX's Avatar
JM-767.pdf
here is Jim's version and their instructions with pics that might help.
Attachment 21053
Did you notice that the Jim’s manual doesn’t protect the seal from the splines?
No knocking their tools. Just noticing
HawkeyeTX's Avatar
Yes, sir. Some instructions leave out "need to know" tips/tricks. The tool does allow for some protection of the inside of the seal to some degree. The seal sits on the recessed portion of the tool offering some protection from the splines, but it's still a good idea to cover with tape or some similar when installing.
This may mean a reversal of some steps for me, but it’s not game changing. I haven’t put fluid in it yet.
Still waiting to figure out if dissimilar fluids will react.
Example: mixing clutch plates soaked in DS with Bely-Ray Fluid
