0 Gear and brake linkage
Last Post: Andy56
0 What oil temp do you run
Last Post: The Doctor71
Last Post: Hardtail28
Last Post: mrmom9r
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
Last Post: Fivecats
1275, big bore kit, custom build, custom oil tank, lithium ion battery
  #901
Old 10th May 2021
BestCoastXL's Avatar
BestCoastXL BestCoastXL is offline
Disassembly Specialist
Sportster/Buell Model: XL883L
Sportster/Buell Model #2: XL883L/1275
BestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond repute
Originally Posted by Tomcatt View Post
I got these: https://sumax.com/product/409-pro-ra...lug-wire-kits/
I'm sure they added at least 10 HP...
I was leaning more towards something like this:
https://s7ns-noise.com/collections/ignition-wires
Old 10th May 2021
Hippysmack's Avatar
I'm gonna end up throwing a mud ball on my fender just to detox from this purtiness.
Old 10th May 2021
I had it out in the rain the other day....gasp
The one plug being a bit black tells me it is firing intermittently and those are plugs wires I made up according to a how-to from Revival Cycles.
The SE wires I have are known good ones so I'll swap those for testing and see if firing improves.
Seven Sins Choppers has some purdy wires. Once I reach an OFP (operationaly functional point) with the bike and am enjoying rides with no need to jump on the forum at every little noise those will adorn the bike as a crowning achievement point.
They even have glow in the dark wires. Snazzy. I think orange will be a good go.
Old 10th May 2021
John Harper's Avatar
John Harper John Harper is online now
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
Originally Posted by BestCoastXL View Post
While I've got you both here,
The trans sprocket (front of belt) I remember as having a small amount of play on its axis. Am i worried over relative nothing?
The sprocket moves in an out a bit toward the case? Or counterclockwise/clockwise? I assume the transmission output shaft does have a bit of endplay, how much IDK. CCW/CC movement is just gear lash, probably normal.
John
Old 10th May 2021
My SE wires were crap. I have some nice Taylor wires now, much better quality than the SE, and not very expensive. I'm rocking purple wires, everyone else has orange, red, or black. Taylors come in many colors.
John
Old 10th May 2021
John
Towards and away from the case. Not an in and out movement but more like a teetering on the end of the shaft. Like the kind that would happen trying to balance a dinner plate on the end of a pencil
Old 10th May 2021
So the sprocket is wobbling on the shaft? Since I have chain drive, I'm not sure how tight the belt sprockets fit on the splines. Most the dirt bikes I've worked on seem to have a bit of freeplay on the shaft, some are just held by a circlip. Seems like it's likely fine to me. I know I've installed some slightly "wider base" chain sprockets that put more meat on the splines of the output shaft.
John
Old 10th May 2021
John
It probably is fine and if there were something wrong there would be belt/alignment issues beyond tracking and likely a constant noise from the primary/trans rather than a rhythmic noise that increases with rpm.
The noise seems to originate from there but I hear it almost as if it were inside the intake manifold.
I held my finger against the slide on the carb the other day and it didn't stop the noise.
I know aluminium is a great megaphone for noise and a noise in one place can be from somewhere totally different.
I'm hoping it's just chain adjustment, because I don't know what a flywheel out of balance noise is like. I imagine there's a severe amount of shaking at all speeds and not just shaking or buzzing at some.
Same should go for any issues with rods, and it seems to me those would eat themselves pretty quickly, especially with the addition of a big bore kit.
Old 10th May 2021
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
You're obsessing again.
1. Check your primary chain adjustment.
2. Set your idle mixture screw to 3 1/2 turns out.
3. Loosen the engine mount bolts. Run the engine for about 30 seconds then tighten (torque) the engine mount bolts.
4. Go for a ride and see how it runs / sounds / feels.
Old 10th May 2021
motorfish's Avatar
motorfish motorfish is offline
Sportster/Buell Year: 2012
Other Motorcycle Model: Road Glide CVO
Other Motorcycle Year: 2009
motorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond repute
Primary chain adjustment can and will have influence on the vibrations, it will vary slightly in the "in spec" range. You did mention a whine from primary on decel, that could be your chain tad on the tight side.
