0 need help with 68 XLH
Last Post: DR DICK
0 Track Bike Build
Last Post: Dusz
Last Post: lehel
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Old 13th September 2021
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
8 watt LED I'll take over 50 watt incandescent on my genny any day.
Traveled to
Sportster/Buell Year: 1969
Originally Posted by mikethebike61 View Post
Just like oil...20-50 is just as thick at 250 degrees as straight 50......5000 Kelvin is 5000 kelvin no matter how you get there....and Sylvania has a 5000 Kelvin sealed beam
Mike the LED head light is superior to the old antiquated seal beam in every way. The LED requires far less energy to operate and will outlast the seal beam many times over. A big plus for the LED on an HD is resistance to vibration. I have literally lost seal beams do to vibration in days.
Old 4 Weeks Ago
gearhead63's Avatar
gearhead63 gearhead63 is offline
Sportster/Buell Model: '70 XLCH, 2000 XLH
Sportster/Buell Year: 7020
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 2000
Other Motorcycle Model: YES
Other Motorcycle Year: YES
gearhead63 is an unknown quantity at this point
Originally Posted by smac74 View Post
My headlight is only bright enough to ride at night by when I'm on the throttle. Is this a normal characteristic? Dont really ride much at night, but probably would if the headlight were brighter.
I've gone through a couple headlights during not alot of miles, but I've attributed that to maybe the fact that its a hardtail and bounces around. This may or may not be the case.
Has anyone used an LED headlight replacement for their ironhead? And how did it work?
Your issue with charging, if you have the stock mechanical voltage regulator, is attributed to that. My original reg fried my generator, so I replaced it with a solid state unit and no more problems.
I SPENT MY TIME & MONEY ON WOMEN, WHISKEY, HARLEYS & GUITARS.THE REST, I WASTED.
Old 4 Weeks Ago
rejeanprimeau's Avatar
https://www.bing.com/th?id=OIP.iDfe2...6&pid=3.1&rm=2
Kelvin is a measurement of how white your light is, nothing to do with power. Take a 5 watts 2000 Kelvin and a 5 watts 5000 Kelvin, the only difference is the color of the light.
Old 4 Weeks Ago
LEDs = Hell Yes!!!
Convert the whole bike to LEDs and you might have enough juice for a heated vest.
The days are getting shorter.....
