0 why you can't be seen
Last Post: Les59
0 Gear and brake linkage
Last Post: Andy56
0 need help with 68 XLH
0 Oil pressure switch
Last Post: Edster
0 What oil temp do you run
Last Post: Andy56
Last Post: Fivecats
0 HSR idle mixture screw
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
Old 4 Weeks Ago
Andy Hog's Avatar
Andy Hog Andy Hog is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: 1964 Triumph 3TA
Andy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant future
Default Help & advice needed
Hi,
81. Yesterday I was out & about on the bike when it just started to back fire & pop, only from the rear cylinder, it was so bad the bike was unrideable, I had to pull over & call for a recovery vehicle to get me back home, which took 4 hours to arrive. The recovery guy said he saw flames coming out of the rear exhaust.
What is the problem & how do I fix it please, until that point the engine was purring along & all was good in the world of Ironhead riding.
TIA,
Andy.
Old 4 Weeks Ago
doodah man's Avatar
You should probably start with push rod adjustment just to see what you find. Then move on to ignition timing components and the timing itself. Original ignition? Maybe it’s on its way out.
Old 4 Weeks Ago
Andy Hog's Avatar
I can't do anything till the weekend, I'll check those rods. I have fitted a replacement electronic system but for the life of me can't remember the make.
If it is the electronic ignition why is it only affecting the rear cylinder?
Many thanks,
Andy.
Old 4 Weeks Ago
Gold Member's Avatar
Sportster/Buell Year: 1972
I'd pull the rear plug and ride it home on one cylinder. A guy I know had to do that one time back in the day and he made it home.
Stop by my build thread:
Four wheels move the body. Two wheels move the soul. Three wheels move the bowels.
Old 4 Weeks Ago
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud of
I've had both PowerArch and MSD V-Series electronic ignitions drop a cylinder on my '78. Current MSD unit is working OK, so far. Never had a problem with the points on my '77!
Eric
Old 4 Weeks Ago
Andy Hog's Avatar
Riding on one cylinder doesn't sound like a good idea, the unburnt petrol would wash away the oil on the cylinder bore which will probably end up welding the piston rings to the bore & the petrol would end up in the crank & then into the oil tank.
Mechanical or electronic, either will fail eventually, just a case of when.
Thanks,
Andy.
Old 4 Weeks Ago
trappnman's Avatar
trappnman trappnman is offline
Sportster/Buell Model: XLCH- old school chop
Sportster/Buell Year: 1973
Sportster/Buell Model #2: 1981 XL
Other Motorcycle Model: Norton HighRider
Other Motorcycle Year: 1971
trappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant future
Andy- as a fyi- on a points ignition Norton, the recommended way to tune, is just as mentioned earlier- disconnect one spark plug and run on 1 side. Its also mentioned that is a failure occurs on 1 side, to disconnect that plug, and you can safely ride it home.
So apparently they weren't worked about gas overflow so to speak, at least for short periods.
CHOPPERS MC S.E. MINN- Chopper for Life- "Old School" Steve Gappa on facebook
Old 4 Weeks Ago
kitabel kitabel is offline
Sportster/Buell Year: 1989
The fuel is a bad lubricant, but it does some good. It's a pretty good coolant when it's not burning.
The "live" cylinder will run very hot, use minimal throttle or it will seize.
My guess? Tight exhaust tappet.
Old 4 Weeks Ago
smokey 2 smokey 2 is offline
Sportster/Buell Model: 1970 XLCH
Sportster/Buell Year: 1970
Other Motorcycle Model: Ultra Classic
smokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of light
I was riding along just fine once and it started popping. My buddy gave me a fresh
spark plug and I was on my way.
WORK TO RIDE, RIDE TO WORK
Old 4 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I don't know why but these bikes sometimes just "eat" a plug.
I do suspect it may have something to do with the fuel additives they are using these days. As they have replaced lead with chemicals things have deteriorated.
I first noticed the problem way back when they introduced alcohol into our fuel. It's not the alcohol, but it happened around the same time. It might just be s deposit on the spark plug that allows it to "track". But if you look at the plug you can't see anything obvious.
