0 HSR idle mixture screw
0 First start question
Last Post: Jaime1840
0 It's Glamazon's Birthday!
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
Old 4 Weeks Ago
If it is in single fire mode one of the cylinders could quit.
If it is in dual fire mode then, No I wouldn't expect so.
Old 4 Weeks Ago
Andy Hog's Avatar
Andy Hog Andy Hog is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: 1964 Triumph 3TA
Andy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant future
I'm not convinced it's the ignition module, with the front cylinder working.
Hopefully I'll get to the bottom of whatever it is over this weekend, & hopefully it won't run into hundreds of pounds to fix it.
Thank you,
Andy.
Old 3 Weeks Ago
Andy Hog's Avatar
Checked the rods, all spot on.
As I couldn't swap over the HT leads, as suggested by one person, I swapped over the spark plugs to see what would happen.
The front cylinder behaved just as the rear was, popping & backfiring, so I put in another new plug & hey presto engine ran great, I took it out for a short ride, no more problems.
Could it really be that simple of a fix, just 2 faulty plugs. Let's hope so.
Thank you all for the help,
Andy.
Old 3 Weeks Ago
mjt754 mjt754 is offline
Sportster/Buell Year: 74
Sportster/Buell Year #2: 62
Other Motorcycle Model: Original flh
Other Motorcycle Year: 63
mjt754 is an unknown quantity at this point
Congrates you did an excellent job.
Old 3 Weeks Ago
Sportster/Buell Year #2: '03
you say you have dual fire ignition.you also say you couldn't switch the plug wire from front to rear,with single fire that's a given but with dual fire?? that's a simple way to find your problem.
Old 3 Weeks Ago
Andy Hog's Avatar
The HT lead on the front cylinder is cut to size, it wont reach the plug on the rear.
Old 3 Weeks Ago
switch the wires at the coil?
Old 3 Weeks Ago
Kingrabbit's Avatar
Kingrabbit Kingrabbit is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: Honda CB550
Other Motorcycle Year: 1974
Kingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to behold
Sounds like a win.
And how easy was that?
Like the guys said: Check the simple things first. Plugs. Plug wires. Coil. Etc.
I’ve had this happen as well.
Old 3 Weeks Ago
Andy Hog's Avatar
The bike has had spark plugs go bad before but it has never caused this problem, just happy it was a simple fix, that doesn't happen often, I'll take that win.
Old 3 Weeks Ago
smokey 2 smokey 2 is offline
Sportster/Buell Model: 1970 XLCH
Sportster/Buell Year: 1970
Other Motorcycle Model: Ultra Classic
smokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of light
Doesn't hurt to carry some spare plugs.
WORK TO RIDE, RIDE TO WORK
