Last Post: mofosheee
Last Post: 73HEAD
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 HSR idle mixture screw
0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
Old 4 Weeks Ago
kusaj kusaj is offline
Sportster/Buell Model: XLH 900
Sportster/Buell Year: 1970
kusaj is a name known to allkusaj is a name known to allkusaj is a name known to allkusaj is a name known to allkusaj is a name known to allkusaj is a name known to allkusaj is a name known to allkusaj is a name known to allkusaj is a name known to allkusaj is a name known to allkusaj is a name known to all
Default Piston melted
Hi guys,
so I have finally got my 1970 Iron XLH 900 running. I have followed instruction from manual and from a bloke who knows what he is doing, but problems occurred.
After about 80km, bike stopped. I have took it apart and found that front piston has partially melted and seized my valves. Obviously running too lean, way too much advanced.
I am running an auto advance distributor/points accel from J@P.
My question is, would you recommend an electronic ignition system to insert into my distributor and if yes which one?
I don't have the points in the side cover but stuck into the right cover from the top, under the carb.
I am in process of rebuilding the top, new pistons, rings, re-lapping the valves, new valves etc. ....
Thanks heaps in advance! some photos:
https://scontent.fakl2-1.fna.fbcdn.n...a7&oe=61702E3C
https://scontent.fakl2-1.fna.fbcdn.n...5c&oe=6170F156
Old 4 Weeks Ago
doodah man's Avatar
I feel like there are not a lot of options for timer ignitions, but this is one of them…
http://www.ebeyond2000.net/index.html
Old 4 Weeks Ago
Thaaaanks, I am having a read about it!
Old 4 Weeks Ago
mrmom9r's Avatar
mrmom9r mrmom9r is offline
mrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond repute
That ignition will melt pistons just as fast as points , good choice.
Old 4 Weeks Ago
Tator's Avatar
Tator Tator is offline
Sportster/Buell Model: ironhead sporster
Sportster/Buell Year: 1967
Tator has a brilliant futureTator has a brilliant futureTator has a brilliant futureTator has a brilliant futureTator has a brilliant futureTator has a brilliant futureTator has a brilliant futureTator has a brilliant futureTator has a brilliant futureTator has a brilliant futureTator has a brilliant future
My 2 cents. As you said you don't melt a piston because of points, you melt a piston from being too lean or to far advanced timing. I have a 1967 XLH with a EBeyond2000 electric ignition. I am very impressed with it, it is far better than points. However, it goes in on the same screws as your points. If your timing is not set right with points, it will not be set right with the EBeyond2000. So go thru your advance unit making sure the springs and bushings are all good and set your timing with the total advance. Then if you do decide to go with the EBeyond2000 it is pretty much maintenance free after that because there is nothing to wear like points.
Old 4 Weeks Ago
Whitewalls's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: 1988 BMW K75
Whitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond repute
Saying points cause engine damage is like saying forks make people fat.
Points merely produce spark. A properly tuned engine with points ignition will run fine with no trouble at all. They were standard for nearly 70 years.
Old 4 Weeks Ago
Sportster/Buell Year: 1969
It's been my experience that Ironheads like advance but they don't starve well. Running too lean is a death sentence. You may run around town forever without a problem but run 90 down the freeway for a mile or two and in the shop you go.
Old 4 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Caveat,My eyesight isn't all that good.
But to my eyes it looks like more damage occurring over the intake valve rather than the exhaust ?
This looks different to the kind of damage I've seen from too much advance.
If it were a too lean condition there will be damage in both cylinders and the rear would generally be worse.
Chamber shows signs of running a little rich before the damage.
What work was done prior to this ? Refreshed top end ?
Old 4 Weeks Ago
Hi, I have been working on the engine from scratch, total rebuild, engine splint in half etc. and worked my way up. I have run the bike about 50km around town and was fine. then I took it up on the road doing about 100km /hour and she stopped with seized valves and melted front piston.
You are correct only front piston is damaged like this. Rear is totally fine.
And yes almost 80% of the alloy from the front piston is collected around exhaust (smaller valve)
What do you think?
Old 4 Weeks Ago
but yes the piston is damaged on the intake side.
